I bought a rebuilt Williams Sys 6-7 driver board on ebay. Seller has a mile long listing bragging on what is done. One thing I recall is stating all the known to be problem issues with this board have been repaired/replaced, board has been Calibrated (still to this day have no idea what that means). At that time I understood the 40 pin needed to be replaced, the 3 watt lamp resistors upgraded to 5 watt, and all the header pins reflowed at the least but replaced is better. I get it in the mail and first thing I see is some dorky looking installed lamp resistors, 40 pin NOT touched and I could see a bent terminal that I would be surprised if any contact could be made with it, also NOT one header pin reflowed. I stupidly sent it back to get the 40 pin replaced. Should have got a refund and went elsewhere. Has been working fine surprisingly till recently a pop bumper quite firing. I pulled it and swapped in a board rebuilt by a pinsider who does great work and the pop bumper is working again. I took a look and 75% of the header pin solder joints look terrible. I bench tested it and all checks out oddly enough. I am hoping that the bad solder connections to the pins is causing an ok connection on the bench but under game stress one is failing. Not sure what else to look for.
Lesson learned, So if you are in need of board repair work start here on pinside, do not fear sending your boards to someone here for a quality repair job. I am not saying all pin repair people on ebay are bad but I know one for sure that is a rip-off who claims to be a repair tech.100_7599.jpg100_7600.jpg100_7601.jpg100_7602.jpg100_7603.jpg100_7604.jpg
