hello,
I am working on a baywatch pin. The back plate of the playfeild has a couple tabs to mount to the lifeguard shack and the largest wire form ramp.
The one for the lifeguard shak, is this suppose to be at an angle or 90 degrees from the back metal plate?
The one lower and to the left of that is for the longest wire form ramp.m there is also a ball protector to keep the ball from leaving this ramp.m are both of these suppose to be above the tab and screwed down? Washers between them? When I took it apart the ramp was below the tab and the screw was just through the small guide peice.
FortyTwo
