So I have a really nice cosmetically Baywatch, but it's just about clean pi**ed me off for the last time. I'm just done chasing problems on this and I know someone else might have patience and time to spend on it.
All bulbs have been replaced with LED's. Sound is great, can play through a game easily minus the issues below.
Here's the issues that I have yet to fix.
* CPU board needs a fuse hack job replaced. Easy fix, just not very good with soldering.
* VKU doesn't work automatically. It will fire the ball after about 5 seconds of sitting in the launcher.
* Shooting arm coil either needs to be replaced or the rail needs to be adjusted. It's not firing up the rail.
* Needs adjustment or a weak coil on the area where the ball comes up from the tray. Ball is just not getting up to the rail.
* Start button needs to be fixed. It is not making a contact, but will if you hold reach in and push it towards the button on the outside.
* comes with the LCD color screen. Needs vertical adjustment on the screen to fit.
So I need some help on a value to move it fast, but not give it away. I might just entertain the idea of tearing it down and parting it out.
I'd appreciate the help!
