(Topic ID: 33977)
Baywatch Club....Members Only!
By dnhayden
6 years ago
  • 3,170 posts
  • 222 Pinsiders participating
  • Latest reply 3 hours ago by northvibe
  • Topic is favorited by 68 Pinsiders
There have been 744 images uploaded to this topic. (View topic image gallery).
There are 3170 posts in this topic. You are on page 64 of 64.
#3151 16 days ago
Quoted from PeterG:
ok, mine is also showing that behaviour. Will that eventually result in gassing out?
That is my understanding of it, yes. I planned on keeping the game and routing. But plan is most likely changing so I am selling, which means the best solution for a display is stock.
#3152 16 days ago
Quoted from PeterG:
Quoted from Chalkey:
I have one from my color dmd replacement. Whatever a used one goes for -10% shipped? I have no idea what it's worth. Make me an offer I guess. Or someone under cut me at 11%.
Thanks! I’ve had some people pm me so I need to figure out what the average used price is. And then get this sorted
#3153 6 days ago
Hi all. Just joined the club, picked up a nice example with color dmd included!
My question to the group is what the differences are with Chad’s Code and where do I get the ROMs?
#3154 6 days ago
Quoted from allsportdvd:
Congrats!
http://www.pinballcode.com/
Changes
http://www.pinballcode.com/bw401
#3155 6 days ago
Contact meloyelo51 at Matts Basement Arcade. He can burn the proper ROM for you... that’s where I got mine and works perfectly. I see he does international shipping as well.
#3156 6 days ago
Honestly, the differences are game changing, (for the good) and if your not using Chads code you're in the dark ages!!
#3157 6 days ago
Quoted from northerndude:
+1!
#3158 6 days ago
chad's code is a must. Best $20 upgrade you can do on this pin.
#3159 6 days ago
Quoted from Langless28:
Will it say 4.01 when I load it or is it best to check my Roma on the board? I don’t know if I have them but I’ll buy them for sure
#3160 6 days ago
Quoted from Happy81724:
It will show the code version when you boot the game.
#3161 6 days ago
+100. Chad's code is a must.
#3162 6 days ago
Okay awesome response! I’ve made contact with meloyelo51 and hope to hear back soon
#3163 1 day ago
does anyone have an extra lift gate rod {wire}?
#3164 19 hours ago
Now that I’ve been testing my Baywatch, the skill shot for the side flipper doesn’t go all the way around to the kicker and lands in the pops. Am I safe to assume a stronger coil is needed? Any other tips here?
#3165 19 hours ago
Have you tried reflowing the solder, cleaning/replacing the coilbushing, and make shure the position of coil and brackets is still good and tightened.
#3166 17 hours ago
Quoted from jorro:
Will try this things thanks!
#3167 17 hours ago
Chad's code helps keep the upper gate open longer for that skill shot. Also check your upper gate to make sure it's fully opening for skill shots, I've seen the wire get bent under the plastic more than once. Also pitch of the machine plays a big part in the success of that skill shot. May want to check both your shooter coil and mess with the pitch of your machine as well as making sure your shooter rod is hitting the ball directly in the center not off centered.
-the guy without a baywatch-
#3168 15 hours ago
The alignment of the shooter coil was the biggest factor. Cleaning the wireform was also helpful. IIRC there is a bit of an up/down adjustment you can do with the exit of the wireform as well.
#3169 10 hours ago
If you have a celephone with slow motion video, try capturing on video. I suspect the wire ramp is too far towRds the flippers. Lossen the locknut and push the wire ramp as far back as it can go.
#3170 3 hours ago
I noticed when the ball would drop from the ramp, it would bounce, hit the gate and go back into the pops.
€ 339.00
Displays
GermanGamingSupplies.com
Playfield - Plastics
3,200 (OBO)
Mesa, AZ
$ 16.00
$ 175.00
Professor Pinball
Professor Pinball
