(Topic ID: 33977)
Baywatch Club....Members Only!
By dnhayden
6 years ago
  • 2,761 posts
  • 196 Pinsiders participating
  • Latest reply 1 day ago by northvibe
  • Topic is favorited by 57 Pinsiders
There have been 660 images uploaded to this topic. (View topic image gallery).
There are 2761 posts in this topic. You are on page 54 of 56.
#2651 3 months ago
HA. Wow, look at those trees. Neat
#2652 3 months ago
Quoted from jorro:
Got my shark, buoy floaty and some trees in
Anyone got some special cool mods?
Hey is your playfield missing some colour in front of the shark targets? Looks washed out.
#2653 3 months ago
After a long dry spell, I finally beat my best score...
#2654 89 days ago
Wow....what a score. I could never score that much. Awesome job.
#2655 89 days ago
Don't blink folks, BW just cracked the Pinside Top100 this week. Watch out, people finally recognizing game!
#2656 89 days ago
Quoted from northerndude:
Yeah!
#2657 82 days ago
I've got my baywatch at my folks house in Cleveland (I live in Arlington, VA) and they just informed me on some issues with the machine. I'm hoping the group can shed some light into what may be going on and how to fix it.
Over the 2-3 months my folks have had the machine, they've noticed that the machine has taken longer and longer to boot up once turned on. The machine apparently takes about a minute for all the lights to turn on, then in 2-3 minutes in the display turns on. They claim it can take upwards of 3-4 minutes before the machine is ready to start a game. If they turn the machine off and back on soon after, the machine won't take as long to boot up.
Now, when the start button is pressed, the music plays as normal, but the ball is not kicked out of the trough into the shooter lane and the display is not going to the skill shot screen. Also, a lot of the lights on the playfield are not on and the U A R D letters (from GUARD) are flashing.
I'm really hoping you can help me diagnose and fix this. Please let me know if this is something obvious, common, or perhaps a known issue on these machines or perhaps inform me as to what tests can be run.
I really appreciate the help!
#2658 78 days ago
per3per3 Without a DMM and real diagnosis, I'd initially suspect power supply board... in my case one of the 'common to fail' caps leaked onto the 12v circuit and caused real screwy issues. I opted for new and swap in replacement, because lazy and trace damage in my case.
https://www.marcospecialties.com/pinball-parts/520-5047-03
...to confirm, check the voltage at test points on this board and see if they're low when the game is trying to power on. Could be as simple as one of the bridge rectifiers too.
#2659 78 days ago
Quoted from mavantix:
Appreciate the advice. Per Lloyd's (LTG on pinside) recommendation, I called Stern's tech support line as apparently they support Data East and Sega machines as well which is good to know. Definitely seems like a power supply board issue and the tech support strongly believes it's the C2 capacitor. I ordered a power supply rebuild kit and will attempt to rebuild the power supply. Since new boards are available for $100, I figured worst case I can always snag one if this doesn't work.
#2660 78 days ago
Quoted from per3per3:
This is excellent to know.
#2661 78 days ago
Quoted from maffewl:
On the stern tour at expo this year we actually saw and original sega board tester fully functional.
#2662 78 days ago
Anyone know where I can buy some of those 4.01 ROMs with the modified code? I just heard about these and didn't even know they existed, sounds like some good updates to make scoring more balanced.
#2663 78 days ago
Quoted from bemmett:
I can burn the chip for you.
#2664 77 days ago
I got em from Matt's Basement Arcade which is on the pinside marketplace.
#2665 77 days ago
I've seen the dimensions posted on a wiki, but wanted to know if anybody could confirm the exact dimensions of the backglass? Mine is missing and the translite is all chewed up :/
#2666 76 days ago
Quoted from jorro:
Cool idea with the trees. Where did you get those?
EDIT: Nevermind, I found a set of 15 on ebay. Thank you very much for the inspiration.
#2667 76 days ago
Quoted from jorro:
Did you drill holes in your plastics to mount the palms?
#2668 76 days ago
Yeah, was just about to ask. There seem to be pegs in the bottom of the trees but I would not want to drill holes. I rather use straps or some tape.
#2669 76 days ago
Looking for a decent condition Ironman plastic if anyone has one in their spares stash
Maybe a Tourist Season one too ...
#2670 76 days ago
Quoted from BioBa:
No not in the plastics
I used an knive to flatten the trunk bottom and then with a small drill , drilled a hole (hollowed out) in the trunk then i put the treetrunk on a bolt and turn it till its firmly down like a locknut works
Use a slightly thinner drill then the bolt tread is and if you can use a tool to hold them so you dont drill your fingers
And offcourse don't palce it where ball travels
On others just used a tiny tiewrap
15417133921821555154540 (resized).jpg1541713505306-1572557091 (resized).jpg15417136011801605123580 (resized).jpg
#2671 76 days ago
O and another trick is heating a paperclip and inserting the wire in the bottom of the treetrunk
The rest of the clip bend it so you can attach it under a locknut or screw.
This way you can place 2 trees on one paperclip and make groups of trees.
You can also dismantle the tree and only use the leafs as foliage
#2672 75 days ago
Quoted from jorro:
You can also dismantle the tree and only use the leafs as foliage[quoted image]
Works well on JP
#2673 75 days ago
Quoted from Ive:
Works well on JP
#2674 70 days ago
I'm not sure what the norm is, but my machine has little pieces of black plastic stapled over the carriage bolt holes (for the backbox) in the side of the cabinet.
I want to put some side blade decals in, but if I ever need to get to the bolt, I'll have to ruin them ... plus it will look very messy with the current solution not being flat and symmetrical.
Are there pre-made plugs one could buy that fit and are fairly flat? Could then just cut around the decal and it'd look fine.
#2675 70 days ago
I removed my carriage bolt covers and did not plug the holes. I installed the pin blades and you can't tell there is a hole in the cabinet.
#2676 70 days ago
Sure, but if I need to get to them, then there is an issue. That was what I was thinking of.
#2677 70 days ago
Quoted from rubberducks:
Are the side blade decals actually decals? I was under the impression that they were like side mirrors in that they are applied to a substrate to be screwed in.
#2678 70 days ago
Wouldn't it be as simple as pull the caps off, put the art blades on and then caps back in? Every art blade I ever purchased had the holes precut. What am I missing?
#2679 70 days ago
I removed the stapled plugs carefully and saved them. Put my side blades on and carefully cut with exacto knife the area where the bolt is. Saved the piece I cut out of the side blade decal and put them back on the bolt when I was done.
601536BA-501E-486A-A6CA-B578F314FEF2 (resized).jpegF9C7ABA2-4438-44F8-ACA7-AEE292F643CD (resized).jpeg
#2680 70 days ago
I can understand if someone needs to access the carriage bolts on a regular basis but I don't see a reason why anyone needs to access the bolts unless you were removing the back box.
#2681 69 days ago
Speaker patches inserted
#2682 67 days ago
Quoted from jorro:
Very nice! Are they perforated? Homemade?
#2683 67 days ago
Quoted from BioBa:
They are real baywatch swimsuit patches, sound passes trough with almost no loss
I just put the volume up a tiny bit
They fit excactly in the plastic insert no glue used just clamp between grill and plastic
#2684 67 days ago
Quoted from jorro:
While I like the idea I can’t see the speakers transmitting very well through those patches. High/mid frequency’s are very directional and those would block the direction of the speakers.
#2685 61 days ago
Any chance anyone has a replacement switch for the right ramp exit (part number 180-5031-00)? The switch doesn't work in test or in game and the there's no continuity.
Also potentially need to replace the switch on one of the drop targets as that's not registering either. Everything else in the game works great.
#2686 59 days ago
Thanksgiving weekend is my time to give all my games a deep clean and wax. Usually, I can get two games done in a day but Baywatch took me seven and a half hours. It's like a 5000 piece 3D jigsaw puzzle and by far has the most complicated engineering of any game I've owned. This is only my 2nd time disassembling and re-assembling the machine so I've come up with a new approach.
Normally, I'll start at the bottom and work my way up, laying out each piece on a towel in its relative position on the playfield. This time, though, I made two piles - one has the low-level posts and plastics laid out as usual and the second is the ramps and habitrails of the upper layers laid out in the order they were removed. This way, I can get the lower level put back first, then re-assemble the ramps and such in reverse order.
Along with the million or so parts to keep track of, there are 13 connections to reset under the playfield. It went pretty well and there were only a few easy issues to fix once it was re-assembled. I also took the opportunity to add a little color.
#2687 56 days ago
So this happened tonight. Noticed my pops weren't having the awesome action as usual.
#2688 56 days ago
But, while under the hood, I installed a new DIY stadium lighting kit I made. I had "borrowed" the one originally on Baywatch for The Shadow.
#2689 56 days ago
My game has suddenly stopped doing the ' Baywatch will be right back' quote when it's switched on - it boots fine , just in silence now
Why would this be ? It doesn't appear to be an issue, just wondering why.
#2690 56 days ago
It fixed itself.
I find that shit annoying since it's cut off in the new Chadware anyway (don't know if it was cut before).
#2691 56 days ago
Quoted from aerobert:
It fixed itself.
It was partially cut off at the end before Chads code also. Don’t know why it does it, Chad would probably know what’s going on.
#2692 56 days ago
Quoted from PinRob:
Don't many Data East / Sega games do it ....? I know my Tommy does, and pretty sure Star Wars does. Someone told me the length of the soundbite relates to how fast your game boots ??
I just wondered why mine had suddenly gone completely
#2693 56 days ago
LW3 and TMNT both do it too.
#2694 55 days ago
Quoted from Wharhed:
I ended up snagging a nos translate off eBay and found the actual dimensions are 26 3/8” x 19 11/16”.
The pinball wiki appears to be wrong on the glass size. They list 26" x 19-1/4" x 1/8" as size for baywatch and a few other sega titles.
I’d be eternally grateful if someone could find a moment to measure and post the actual dimensions of their glass.
#2695 55 days ago
lol played a bit yesterday and the ball drained during CPR mode. Had that stupid song play in the background instead for the whole duration of the game until next credit.
#2696 55 days ago
I just measured mine, and it's approximately 26 1/2" x 19 3/4". The PinWiki dimensions were wrong. I've reached out to the person who manages that page.
#2697 55 days ago
Quoted from gweempose:
Thank you! I appreciate it.
Btw - was that with or without the trim installed?
#2698 55 days ago
It was with the trim installed, but I tried to measure just the glass as accurately as I could. Unfortunately, I couldn't easily remove the trim because it still had the super sticky factory black tape.
#2699 54 days ago
That works for me. I was just going to deduct the ~1/16" of thickness that the trim adds from the measurements you provided. Thanks again!
#2700 54 days ago
My shooter lane switch has died for the third or fourth time this year. Why in the hell does this keep happening? Anyone got any ideas!?
