(Topic ID: 33977)
Baywatch Club....Members Only!
By dnhayden
11 years ago
  • 5,117 posts
  • 324 Pinsiders participating
  • Latest reply 3 days ago by HiRez00
  • Topic is favorited by 98 Pinsiders
There are 5,117 posts in this topic. You are on page 49 of 103.
#2401 5 years ago
Quoted from FatPanda:
Here is the switch schematic. Looks like CN8 and CN10 are associated with the playfield switches. Check the connectors, header pins, etc. for anything that shouldn't belong or for any cold solder joints. Would probably be beneficial to reflow the solder joints to all the header pins since you'll have the board out.
Pulled the board, reflowed the header pins, obviously reseated 8 and 10 as a part of that. Reseated the flipper board connectors too. No change. Right flipper plunges the ball and fails the skill shot. Squid pops happened, no idea what that means though.
#2402 5 years ago
Quoted from desertT1:
Squid pops happened because the right inside inlane switch was triggered due to the problem. I still want to lean towards something going on with the right flipper switch and the shooter lane switch. I believe something physical is causing your errors whether there are wires or lugs touching that shouldn't be touching, or there's a short somewhere, etc.
Perhaps start a new thread to get some other (smarter) folks involved. They will have more technical knowledge than I do. Posting the pics of the switch test and all of your troubleshooting steps covered so far will be helpful in the new thread.
#2403 5 years ago
Don't only focus on the two switches/diodes that are directly involved. Instead, you need to check ALL the switches in the associated Rows and Columns of the Switch Matrix.
#2404 5 years ago
Quoted from ChadH:
I certainly wouldn't discount any of the other switches, but I think it would be a good starting point since it's the combination of 1 trough switch, shooter lane switch, and right flipper switch that causes the issue. Hopefully someone with more technical knowledge can chime in on the other thread.
#2405 5 years ago
I bought a replacement power board from Marco and installed it this week... I immediately noticed a number of things that occasionally worked or just rarely got activated started working.
I hadn't seen the automatic shark flip happen in the last 12 months, I rarely saw video mode of the skier in the last 6 months, tower ball locks weren't giving the locks occasionally or giving a couple of locks when only 1 was earnt.
All this seems to be working great now... unsure why, but sure am happy.
There's a few things playing up still but I'll get to fixing them soon enough with a bit more reading and knowledge from the forum. Thanks to you all!!
and currently... I'm practically running through central Melbourne (Aust) carrying the box I received today which has my ColorDMD in it, trying to get home at breakneck speed to fit it.
Outta my way non-pinball people!!
#2406 5 years ago
For the switch/row issue, check the diode that is on the switch for the shooter lane, I have had mine touching a piece of the metal bracket that is there or something causing a short before and switch issues, took me a bit to spot it.
Also is anyone else having trouble with their shooter lane switch? I had the game at home for years with not issue then I put it on location and it has broken 3 times now.
#2407 5 years ago
Quoted from Tsskinne:
The armature snapped off on mine, but after replacing it, no issues.
#2408 5 years ago
Selling my original DMD for Baywatch if anyone needs one...time to get some color!
https://pinside.com/pinball/market/classifieds/ad/63990
#2409 5 years ago
It took a lot of tweaking to get mine just right, including adjusting the actuator as well as the height of the habitrail.
#2410 5 years ago
Sooooo... this happened.
It's a result of increasing the extra balls to 5 per game plus the notoriously generous ball saves. I was able to play three Earthquakes and get jackpots of 210 million per tower shot by the end. The game wasn't even over - it just maxed out and wouldn't award anything more than 10 digits. Has anyone come across this before?
Like @eurotimmy, I've been having some other weird issues, including:
- Shark awards won't advance. The only time I've seen the water ski video mode since installing the ColorDMD is from a Search & Rescue award.
- The laser kick seems to be permanently on after reaching Earthquake. Is this a feature of the 4.1 code?
- I can sometimes lock a ball from the Shark hole. When it happens, a 2nd ball will kick out and auto-launch and regular play will resume. I can start modes, etc., just with two balls instead of one. When one of the balls drains, the game just keeps going like nothing happened.
- I don't know what the rules of the ball save are. I don't think anyone really does.
Do any of these things happen to anyone else?
#2411 5 years ago
Quoted from TopMoose:
Doesn't make sense. Something is wrong.
It's on for the remainder of the ball. This is how it was in 4.00 and there was no change to this in 4.01.
Doesn't make sense at all. Sounding like maybe you have a bad Shark Hole switch? Is your game kicking out a ball because of Ball Search? What happens in Switch Test mode with the Shark Scoop? Maybe give all your switches a test while you are at it.
Start-Of-Ball Ball Save timer was increased from 5 seconds (in 4.00) to 7 seconds (in 4.01).
Shark Scoop/Laser Kick Ball Save timer was increased from 2 seconds (in 4.00) to 3 seconds (in 4.01).
#2412 5 years ago
First of all, judging by that score you are a seriously good player, and you need to increase game difficulty settings - not decrease them! Reduce your extra ball limit and increase your mode start criterion difficulty. Also, if you have your replay award set to Extra Ball, change it. If that doesn't work, play with one hand and/or blindfolded!
If the weird things happening in your game with the shark hole and shark awards aren't attributable to a simple switch/connector issue, then I would suspect a corrupt or perhaps poorly seated chip on your CPU board.
Good to know that the game pegs out at 10B. I'm adding that goal to my bucket list.
#2413 5 years ago
Quoted from sudsy7:
That score was a fluke and in no way an indication of my usual skills. I'm definitely limiting extra balls to 3 in the future.
A lot of the weirdness I described seems to center on the shark hole switch, so I'll check that out first. Then I can check the new ROM I installed and maybe re-install the old 4.0 chip to see if the problems persist. I may start a whole new forum topic so as not to take up too much more space here.
Quoted from ChadH:
Agreed, but this particular problem seems to have started after I installed the ColorDMD. Could there be a correlation? What's weird is that when I make a shark flip shot, I still get the cartoon shark and flying chum animation, it awards 25M and kicks the ball back out. The only strangeness is that the award doesn't advance.
Quoted from ChadH:
Good to know - I'll check that off my list.
Quoted from ChadH:
There's no ball search when this happens - it behaves exactly as if I'd locked the ball in the tower. This was happening before I upgraded to 4.1, so it's not a ROM issue - probably mechanical or a problem elsewhere on the boards. I'll do a switch test and see if I can solve the mystery. Current theory: the impact of the ball in the scoop is triggering a subway switch, which registers a locked ball and kicks out a new one. The scoop then ejects its ball, like it's supposed to and the game continues. But the game also keeps track of all five balls and when one drains, the game keeps going because it know that there should only be one.
Quoted from ChadH:
Does each mode have its own ball save? Because if I drain within the first few seconds of a mode, it will usually give it back.
Thanks guys!
#2414 5 years ago
I would definitely go into switch test to see if one switch triggers other switches (or a combination of switches). Incorrectly wired switches or diodes can cause other switches to trigger (as we found out with the previous problem). The display shouldn't cause any issues, but I would go back and double check ribbon cables, grounds, etc.
You can check if impact is causing switches to trigger by going into switch test and pounding the pf with your fist.
#2415 5 years ago
Sounds like the playfield switch in the lane right above your Shark Flipper is not working. The animation you describe is not related to a successful Shark Flip. That animation is played when the ball just happens to enter the Shark Hole randomly. Hitting that lane switch above the Shark Flipper should trigger the shark animation where he is coming out of the water at you and plays the Jaws type music.
No.
#2416 5 years ago
Very unlikely, the ColorDMD just reads the screen output and converts it to color (I'm over simplifying), and shouldn't impact switch reads or logic at all.When you get the reward a second time is the number of points awarded different than what is displayed?
#2417 5 years ago
For what it’s worth after I installed colordmd I hit the shark hole and started water skier video mode and during video mode two balls were sent into play. Haven’t tried it recently to see if this still happens but I will this weekend. And I’m not certain if this happened after ColorDMD install or after I installed the new code, just that I noticed it after ColorDMD installation.
#2418 5 years ago
Quoted from PinRob:
After I installed ColorDMD during video mode two balls were sent into play.
That makes sense, since adding ColorDMD makes playing just about any pin twice as much fun.
#2419 5 years ago
With the second and third skill shot the upper right gate isn’t opening until the ball has just bounced off of it. Seems to be at least a full second delayed. What can cause this? Seems like a pretty simple small coil and 2-3” lever.
#2420 5 years ago
I had the exact same problem with mine. I solved it by doing two things. First, I re-flowed the solder to the coil to make sure it had a good connection. Next, I bent the metal lever down a bit so it was closer to the magnet. It has been working perfectly ever since.
#2421 5 years ago
So this happened...
Looks like I need to shorten the gap on those posts...
Lost 2 of them while trying to keep them all in play with the glass half off, flipper up and getting the balls to cradle in the right flipper.
That's pinball I suppose!
#2422 5 years ago
Wished I had time to play pinball I have my color DMD and have not installed it......I'm working 80 hour weeks
#2423 5 years ago
I replaced the bridge rectifier on my power board and that resolved the game reset issues. Game wouldn't fully reset, but usually the sound could cut out for a bit and also you'd see the CPU info on the screen while it said Baywatch Will Be Right back.
Found an issue with the ColorDMD on the jiggly tits (every girl jiggling) match screen. One of the girls had I think "1P" flashing behind her and the bottom half of her was flashing yellow while the top was white/gray.
#2424 5 years ago
So this happened...
Lol..
Looks just like the 5 ball shark hole incident !
See Panda it does happen
#2425 5 years ago
Quoted from PoMC:
This has been fixed in the latest code which hasn't officially been released yet.
#2426 5 years ago
Quoted from Dmod:
Sorry you’re having trouble. Check to make sure you have the wide ribbon cable installed properly on the display board. Red stripe should be closest to pin1 (near the large chip).
Reversing this would screw up communication on the data bus and could cause strange behavior.
Thanks, the trouble was definitely my game and not the ColorDMD. I replaced the power supply and the Baywatch babes are back up and running the beach, now in glorious color! This thing is awesome.
#2427 5 years ago
This is interesting.
Look at my left side graphics.
The 2 girls have white bathing suits and it's not faded.20180512_132855 (resized).jpg20180512_132855 (resized).jpg
Any one else like this ?
#2428 5 years ago
But my right side is like this
#2429 5 years ago
Not sure if this minor coloring "issue" has been found for the ColorDMD. When playing Guard mode (I'm the lifeguard!) I drained on my last shot to make so I was able to look at the screen and watch. It shows the point value for all made GUARD shots and one of mine was 39 million. The 9 was in red but every other number for the points was yellow.
#2430 5 years ago
Quoted from golfingdad1:
That is odd...mine isn't white at all on the left side bathing suits...
#2431 5 years ago
It's faded for sure, the reds are just the first to go and the other colors aren't affected near as much. The suits are red on the bottom and fade up to white, looks like the bottom half saw less light. The red accents around the sun are there on your right side, but follow the same line on the left, no red on the top.
#2432 5 years ago
Quoted from PoMC:
Guard millions? Remember which of the five positions the broken 9 was in?
Oh wait, it was the single total screen? Post a picture of the screen you’re talking about if possible, even if the numbers are different
#2433 5 years ago
Quoted from FlipperMagician:
I'm not sure about that?
I cant answer it either .
The girl near the flipper has a white top, but nothing else is off.
#2434 5 years ago
Also your girl near the flipper , and I dont want to say ,but her top left breast sticks out alot more ?!?
Dont ya think?
In all fairness i would say my right side has more fading than my left.
#2435 5 years ago
Quoted from epthegeek:
I'll keep my phone handy next time. I think it was the 3rd position from the left.
#2436 5 years ago
Installed my ColorDMD and loving it.
Strange thing... I got a score of 50,901,090
The first 0 on the left side (next to 5) came up white and all the others where coloured.
Am I making sense, is it a missed colorization?
#2437 5 years ago
Quoted from Eurotimmy:
If you can post a picture but also describe like you did. It will help EP find the missing color
#2438 5 years ago
Score during the game? or score after the game was over during attract?
#2439 5 years ago
I figured out the problem with the Guard Millions "9" digit - so that's fixed.
I have an after game score single player with double digit millions that detects properly for the zero on the second digit -- so I'll need more detail on that one I guess.
#2440 5 years ago
I was just too slow to get the photo and haven't been able to recreate it since.
From memory I had the ball in play, or had only just lost it, then I took this (admittedly pointless) shot so I could remember the score for posting to you.
Photo just for evidence.
I'll try to recreate the score on that ball again and see what happens... as soon as I'm back on my machine.
NB: not running the new 4.01 chad code yet.
#2441 5 years ago
How are we not in the top 100 yet.
#2442 5 years ago
Quoted from Langless28:
I agree. Such a fun game. The color dmd is awesome!
#2443 5 years ago
I've had issues with the ColorDMD where it will show the boot up screen (Display Version screen) in the middle of gameplay. Sometimes it's just for a short period of time, then it goes back to normal, other times it's an extended period of time. Also during the match sequence, as it scrolls through the girls, the second from left girl will sometimes be translucent and show the "MATCH" screen behind it.
#2444 5 years ago
ColorDMD can't put things on the screen - if it's showing the boot up screen, the game is doing that. All the ColorDMD does it apply color to what is showing.
The match issue was patched and is in the ROM that will be released soon-ish.
#2445 5 years ago
Do you have an original Data East power supply installed? If so, has it had new capacitors installed?
#2446 5 years ago
Quoted from PinballManiac40:
I haven't done any work to the power supply, and i doubt that anything was ever done to it in the past.
Just seemed odd that it has never down this before and I'm only seeing now.
#2447 5 years ago
Sounds like a coincidence. Can you measure the 5v and 12v on the power supply and snap a picture of it?
#2448 5 years ago
I was having that happen, kind of like a soft reset but the game continues. Was usually being triggering by the pops or other coil activity. Sometimes the music would cut out for a bit too.
I replaced the bridge rectifier on the power board last week and the issue is resolved.
#2449 5 years ago
You want a picture of the PS?
#2450 5 years ago
Quoted from PoMC:
Do you know where I can find values/part numbers etc.? Can't seem to find them in the manual from the quick skim.
$ 32.00
$ 27.95
$ 16.00
$ 175.00
Professor Pinball
arcade-cabinets.com
$ 17.00
Nordic Pinball Supply
Playfield - Plastics
$ 33.95
Mitchell Lighting
4,500 (Firm)
Howard City, MI
5,900
Anderson, SC
$ 24.00
$ 9.95
$ 27.95
$ 22.50
$ 259.00
$ 33.00
$ 36.95
$ 22.50
$ 18.99
Tools
FlipMods
$ 60.00
This page was printed from https://pinside.com/pinball/forum/topic/baywatch-clubmembers-only/page/49 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
