(Topic ID: 33977)
Baywatch Club....Members Only!
By dnhayden
6 years ago
  • 2,968 posts
  • 209 Pinsiders participating
  • Latest reply 5 days ago by Rocketrob
  • Topic is favorited by 67 Pinsiders
There have been 709 images uploaded to this topic. (View topic image gallery).
There are 2968 posts in this topic. You are on page 45 of 60.
#2201 1 year ago
Good advice by sudsy. Definitely check to see if the flipper switch is shorting something else out. Also check the other switches that are activated with the flipper button to see if there are any loose connections or wiring. Make sure all switches and mechs are fully secured and aren't messing with other wiring and whatnot. Have you done any soldering recently and possible have dripped solder onto something? That'll cause issues too.
#2202 1 year ago
Quoted from desertT1:
Had an idea. With the ball in the shooter lane, it just shows that a ball has moved from the trough to the lane. With the ball in the lane and the right flipper pressed, several switches on the far right column go active.
Check the diodes on all the related switches. Also check for shorts.
#2203 1 year ago
Quoted from ChadH:
I was just about to say the same thing.
#2204 1 year ago
If its the right flipper, it also could be something on the "shark fin" flipper
#2205 1 year ago
Very easy to short between the flipper button switch and the auto plunge mech diode, had it happen on mine before inspect closely.
#2206 1 year ago
I sold the DMD from my Baywatch and mailing it out tomorrow. I'll move Baywatch to the workshop and replace the bridge rectifier causing some soft resets. Then I guess patiently await the X-LED release in April / May.
#2207 1 year ago
I lifted the playfield (so it's resting on the prop rod) so the right flipper switch has no chance of touching the shooter lane diode. Pressing the right flipper by itself doesn't do anything. Pressing the shooter lane switch lights up just that switch, but then pressing the right flipper adds that switch PLUS the right slingshot. Visual inspection of wires and diode at the sling looks good. Going to test now. Am I in the right area, or would a different diode be triggering the sling?
EDIT: The other corner of the square in the matrix is the #5 trough switch. That one was closed while the playfield is up. When I moved the ball so that switch isn't closed, the above button sequence doesn't light up the slingshot. With trough switch number 5 active, the sequence triggers the sling.
#2208 1 year ago
I would focus on the right flipper switch. If you switch boards from left to right does the problem follow?
#2209 1 year ago
Boards? These are double stacked leaf switches on both sides.
#2210 1 year ago
For some reason I thought they were opto boards. Sorry!
#2211 1 year ago
It would be a bit of a pain, but it might be worth swapping left to right to see if it does anything.
#2212 1 year ago
Hi all,
I am working on a project Baywatch. Summary of current issues here: https://pinside.com/pinball/forum/topic/need-help-diagnosing-a-project-baywatch
I am posting here to find out if anyone knows the specs for the Babcock DMD power connector (P1). My connector on the wires does not match the Babock DMD header. Image of DMD here: https://photos.app.goo.gl/Z1H6O1GN0TDV2jQj1
If anyone knows the part number at Digi-Key or Great Plains, that would be a big help to move forward in my diagnosis.
If there are any other questions you could answer, that would be a big help too. Thanks.
#2213 1 year ago
Got my Baywatch yesterday.
Though the cabinet is far from pristine, it is fairly unfaded. It also exhibits much darker blues and more vivid colours than many examples seem to. Some of this is of course down to fade, but a lot of machines appear to have been quite 'milky' and pale looking, according to old photos, new photos of supposedly unfaded but still pale examples, and the look of replacement decals (which are also pretty pale).
It looks far, far better than the pale examples IMO.
Were there two different sets of colour keys used? Maybe the paler ones were decals? My cabinet is direct printed.
#2214 1 year ago
Quoted from Meloyelo51:
I can help with roms...PM sent
Thank you Matt for burning the 4.1 Rom from Chad H and for shipping it out so quickly. Now I just need to donate to the Chad, and how do I do that?
#2215 1 year ago
Quoted from Robb63:
Go here: http://www.pinballcode.com/
Button is there
#2216 1 year ago
Thank you for posting The bodacious score cards it was so easy to print out and I can’t wait to put them in my game tonight I will post some pictures later I installed new mirror blades and made my own Led Pin lighting strips and what a difference that made . I also replaced the European coin door with the correct USA one and will install the Sega sonic the hedgehog decal as well that I just had printed..
#2217 1 year ago
Quoted from Robb63:
That SEGA coin door sticker looks the goods!
Has anybody printed multiples of these and looking to sell one and post internationally?
#2218 1 year ago
Quoted from Robb63:
The coin door decal looks pretty good. What media and what type of printer did you use?
#2219 1 year ago
Quoted from Robb63:
Let's just have Robb hammer off a couple dozen of them and mail them out to us!
#2220 1 year ago
The bodacious decals I made myself out of printable paper with a sticky back and then I put a clear decal over the top of it Sonic the hedgehog I just downloaded your decal onto a zip drive and handed it to a printing company I don’t know what she used but she has some expensive equipment.
#2221 1 year ago
Quoted from Robb63:
I thought the quality looked too good for a home printer - looks as good as an original. Not sure how much she charged you for making that sticker, but you probably wouldn't have too much trouble selling 20 of them if the price was reasonable.
#2222 1 year ago
I have a few extras $15 each with free shipping? And for $20 you get both a bodacious scorecard with either Pam or Brooke your choice and a Sonic the HedgeHog Decal..
#2223 1 year ago
Quoted from Robb63:
I'll take a set please .
#2224 1 year ago
Quoted from Robb63:
Ya I’ll take one with Pam
#2225 1 year ago
Quoted from Robb63:
I would love a set! PM sent!
#2226 1 year ago
Me too PM sent! Awesome job
#2227 1 year ago
Nice work. I'm in! Pm sent
#2228 1 year ago
Great send me a PM touch base with me..And I will send you instructions.. Thanks Robb
#2229 1 year ago
Quoted from Robb63:
PM sent.
#2230 1 year ago
Quoted from northvibe:
Pm sent
#2231 1 year ago
Pm sent just in case!
#2232 1 year ago
I’m trying just can’t seem to pm Might have to wait till tomorrow
#2233 1 year ago
pinrob asked me to post a pic of this board. Which reminds me I need to fix the stand-offs.
#2234 1 year ago
On my shark kickout, the switch does not always register and trigger the kickout about 40% of the time. Usually if I flip the left flipper it will then trigger the switch. All connections are good and I replaced the switch. Any suggestions?
#2235 1 year ago
Quoted from Don44:
Just because it's a new switch, doesn't mean it's working. Those switches (even new ones) are notorious for performing poorly.
Swap that switch with the one in the VUK (diver trapped). See if the problem follows the switch.
#2236 1 year ago
Quoted from northerndude:
Ok extra saved for you PM me.. Thanks Robb
#2237 1 year ago
Quoted from Don44:
Quoted from ChadH:
Also, can you go into switch test and use a ball with your hand to see if it is registering correctly?
#2238 1 year ago
Quoted from Don44:
sounds like switch needs adjusting. Ball might be bottoming out before activating the button on the switch
#2239 1 year ago
Ok I got a $20 paypal payment from Stephen R but he did not leave his instructions in the Paypal Notes. Please reply Stephen R.
#2240 1 year ago
I recieved my two scorecards and the coin door decal today Thank you Robb63 for the awesome work. The best part is the scorecards are peal and stick
#2241 1 year ago
Hello everybody, I joined the great world of pinside today! And I have a question about my Sega Baywatch pinball table: seems that as of yesterday, some switches activate multiple switches simultaneously, ghost switches. Actually all of the switches that show this behaviour are connected via green/yellow cable to CN8-4, Q52; switches: 25, 26, 28, 30, 31 and 32. Slam tilt is one of the ghost switches activated by switch 31. This stops the game. I unplugged / replugged all plugs / cables from the boards, but no joy. Do I need to buy a new CPU board? Baywatch #sega #dataeast #ghostswitch
#2242 1 year ago
Quoted from Move-your-car:
No, you do not need a new CPU board. Send it out for repair or try to learn to repair it with some advice here. Can you solder well on boards?
#2243 1 year ago
I finally got to check out the ColorDMD in Baywatch at MGC this weekend! The thing looks awesome! Eric did an amazing job as usual on the colorization.
#2244 1 year ago
Quoted from gweempose:
Hopefully it will be available soon This will be my first Color DMD purchase
#2245 1 year ago
I finally got to check out the ColorDMD in Baywatch. The thing looks awesome!
Quoted from hawkeyexx:
Hopefully it will be available soon.
I really need this one. Just waiting for it to be available to order.
#2246 1 year ago
Anyone else peruse around that Baywatch for sale thread?? LMFAO
#2247 1 year ago
Yeppers......fun way to kill time and see what everyone is posting
#2248 1 year ago
I'm more interested in coming up with ways to fix insert art cracking when they raise slightly. My inserts are not that bad (compared to ad pictures) but eventually I will need to figure out how to fix them for a restoration and I hope it doesn't involve fully reprinting areas. Other than insert cracking my playfield is in top notch shape.
#2249 1 year ago
Quoted from Langless28:
I'm sure you can an answer from someone who restores playfields.
My Baywatch has been shipped to ardvark pinball for Nvram update. I'm having all boards serviced and repaired. My Ciffly protector has shipped this week
#2250 1 year ago
I understand if boards are being overhauled but nvram is plug n play on these boards FYI.
