Other than the usual DMD,cabinet fade anything extra to look out for bad or good?
Make sure it has the correct legs ! Should all measure 30 1/2" ( black w/ yellow sticker at bottom ) Try the third skill shot to see if the shooter makes it all the way around the wire ramp and down to the kicker . Check for broken plastics as in the one above the drop targets . After that it's all good !
Quoted from TenaciousT:Make sure it has the correct legs ! Should all measure 30 1/2" ( black w/ yellow sticker at bottom ) Try the third skill shot to see if the shooter makes it all the way around the wire ramp and down to the kicker . Check for broken plastics as in the one above the drop targets . After that it's all good !
Yellow stickers on legs? Never seen that and honostly wouldn't make it a deal breaker or even a priority. DMD is the main thing to check.
DMD is the main thing. The rest is not show stoppers if you can get it at a good price. The part of the DMD controller board is vital. If the screen is toast you can always do the DMD extender from Dr. Pinball and make it a color screen which I am working on right now.
Quoted from dgoodspeed:DMD is the main thing. The rest is not show stoppers if you can get it at a good price. The part of the DMD controller board is vital. If the screen is toast you can always do the DMD extender from Dr. Pinball and make it a color screen which I am working on right now.
Have to post a pick when you are done. Will be curious to see a color screen on Baywatch.
This page was printed from https://pinside.com/pinball/forum/topic/baywatch-advice-not-price and we tried optimising it for printing. Some page elements may have been deliberately hidden.
