Thought I'd share my experience in changing out the 2034 Coin battery in my CBW.
Purchased the battery holder from Mouser Part #614-HU2430-LF
Picked up a CR2034 Battery from Battery Plus - couldn't find this battery anywhere else!
I used these pages for help
http://www.beerorkid.com/pin/Gottlieb%20system%203/
Pulled the board from the game tonight and took the time to document with pics as I went. Might help someone else who might go thru same process.
This pic shows board and prep area - to get battery off, I used solder sucker to remove most of solder on the 3 solder points on the reverse of the board, then gently pulled on battery as I heated the thru pins from behind.
In this pic you can see the first pin (negative) free from board
Here you can see the entire battery removed after I heated and pulled the remaining 2 (positive) pins
In this image you can see the battery is gone from the board - I will re-use the top positve pin hole but will NOT use the bottom one and will NOT use the negative hole at all
In this image, I used an awl to scratch off the board coating to access the negative trace near the battery holder that I will now install. See the scratched area at the end of the awl point.
Here you can see the part I bought from Mouser. It has 2 positive legs and 1 negative. I cut off the lower leg of the 2 positives (in the image it would be the right leg). I then "bent" the negative leg and trimmed it to needed length (see next pic)
Here you can see the negative leg that I needed to "bend" and trim in order for it to "meet" the spot on the board that I had scratched down to the negative trace where I will solder it to (reason for all this scratching and soldering to a trace is that the new battery holder is larger than the original and the negative pin hole does not line up)
Here you can see I put the battery holder on the board by inserting the one remaining positive pin into the top "old" hole from the original battery holder and then checked the "length" of my newly bent and trimmed pin to make certain it matched my scratched spot perfectly - it did. I left the battery in to make certain there was clearance over the chip right below it.
Here's a shot of the same but without the battery installed (make sure you solder it with the battery removed!)
Next I soldered in the positive pin into the hole marked "A" (looking at board from front it would be the "top" pin hole of the 2 positives from the original holder mechanism. Holes labeled "x" are not used again.
Here is the view from the front with the positive leg soldered in
Here is the final pic with the negative leg that I "bent" and trimmed soldered onto the trace that I exposed on the board.
Game booted as error code Uxx errors first time
Game booted perfectly second time
Note that CBW will boot in tournament mode if you had it set to free play and will allow unlimited balls until you shift it back to Free Play and whatever ball count you wish
Nice to have this machine back booting well and not having to go into backbox to get it running!
