After sitting for the winter, my Fishtales wouldn't boot, and the CPU LEDs indicated an error. I noticed a bit of battery leakage damage on the U16 pins and I assumed I was in trouble. However, after disconnecting and reconnecting all of the connectors on the CPU board, the machine boots up and runs fine. I played several games without a problem. The question is, should I still pull the CPU board and at least clean the effected area with water/vinegar. I'm worried that the problem may get worse if it goes unattended. By the way, I'm a bit of a pinball newbie. Thanks
