(Topic ID: 315273)
Batman forever switch issues
By Iliketofish
1 year ago
#1 1 year ago
Left flipper engages all row 8 switches. Test mode each switch tests good except when I press the left flipper. When I press that one, it engages not only itself, but all the switches in the same row. Any advice would be greatly appreciated. Thank you for your time.
#2 1 year ago
Any chance you have after market flipper PCBs in the cabinet?
#3 1 year ago
No. I have original board in. I did buy one but had issues with it so put original back in. Bought one because I thought the original board was giving me issues and fuse clips are all very weak or broken. Replaced all flipper components and all was good.
#4 1 year ago
The left flipper switch is in row 7, column 8. Do you mean it engages all column 8 switches?
Check for shorts to ground around it and the other switches that are activating.
#5 1 year ago
Transistor or diode fault on one of the switches.
#6 1 year ago
Thanks guys! Only 7 months in the hobby. Still have a lot of learning to do. Learning to navigate pinside. Found a lot of old posts similar and doing my research. My Batman forever is definitely giving me my challenge. I finally figure out one issue to only run into another. I appreciate your time.
#7 1 year ago
Sounds like a broken wire to all those switches in the row. Be sure to tug on the same color wire to be sure it is connected at each switch and they are soldered to the correct switch solder tab of the switches.
$ 18.95
$ 50.00
arcade-cabinets.com
$ 7,995.00
Pinball Alley
$ 27.95
$ 27.95
$ 50.00
arcade-cabinets.com
$ 29.95
$ 17.00
Nordic Pinball Supply
$ 259.00
$ 27.95
$ 17.95
Professor Pinball
$ 24.95
Mitchell Lighting
$ 32.00
This page was printed from https://pinside.com/pinball/forum/topic/batman-forever-switch-issues and we tried optimising it for printing. Some page elements may have been deliberately hidden.
