(Topic ID: 65385)
Batman Forever DMD Problem (Now Solved)
By Jasonba
10 years ago
  • 7 posts
  • 4 Pinsiders participating
  • Latest reply 10 years ago by Jasonba
#1 10 years ago
Hi guys,
Just wondering if anyone can assist with this problem I'm having with my Batman Forever DMD. I was playing last night and it suddenly went blank. I turned it off and on again to see if it came back but it did not.
I have reseated the connectors at the back of the display panel and on the boards. It has come back on but all I get is a full block display with a couple of vertical lines. I have turned it off and on a couple of times and the vertical lines aren't always the same, to begin with there were more lines missing now it seems there are only a couple.
If anyone has any suggestions as to what I should look for, I would be happy to hear from you.
Picture attached, Thanks in advance,
Jason
Problem solved see post further down
Post edited by Jasonba : Problem solved
#2 10 years ago
Get ribbon cables back on red stripe pin one each end ?
#3 10 years ago
Thanks LTG, Your always first to reply
Will check that first when I get home. (At work for another 7 hours). Will report back then.
Jason
#4 10 years ago
Does anyone have a translite for sale for this machine?
#5 10 years ago
Hope you can fix it , that is one expensive DMD i had to buy one.
#6 10 years ago
Quoted from pinbum:
Its $500 for a new one here in Australia and he has only two left.
#7 10 years ago
All fixed. In the process of checking that the ribbon cables were the correct orientation, as LTG suggested, I reseated all of the connectors again and it worked as it should.
PinSound
$ 18.95
$ 5.00
$ 29.95
$ 50.00
arcade-cabinets.com
$ 27.95
$ 24.95
Mitchell Lighting
$ 27.95
$ 259.00
$ 50.00
arcade-cabinets.com
$ 27.95
$ 17.95
$ 7,995.00
Pinball Alley
$ 32.00
$ 5.95
The Pinball Scientist
$ 299.95
Pin Stadium Pinball Mods
This page was printed from https://pinside.com/pinball/forum/topic/batman-forever-dmd-problem and we tried optimising it for printing. Some page elements may have been deliberately hidden.
