Pin_Crazed,
Thanks for the reply. I checked the switch for the cannon registering a ball a bunch of times. It seems to register it every time. I didn't try hitting the + or - in test mode. I was selecting the "RUN" feature, I'll try that when I get home. I just kept restarting the game and loading a ball into the cannon (bat cannon is ready on startup). So it would make my life a hell of a lot easier if the + and - worked to move the motor. Can you check on your BF and see where in the menu that you can move the motor? I think I'm in the right spot. I'm trying to actuate it where it say batwing cannon motor relay.
When I removed the motor assembly to test the "home" switch is when I got confused. There are two tires coming off that switch. I would assume that when you disconnect the cable and you hook up an Ohm meter to the end of the wires and open/close the switch, you should see a change from OPEN to 0 ohms. I did that and there was no change. But if I go directly to the switch points (before the wires) the switch tests ok. It looks like there are 3 leads coming off the switch with only 2 wires. One of the leads has a capacitor looking guy that is soldered to the other lead. Then there is a wire between the two. The one lead between the two outer leads, and one of the leads that has the capacitor soldered to the other one have wires going to the cable connector. So when I measured and the switch tested good, was when I measured across the two pins with the capacitor looking thing in between.....but those aren't the leads that go to the wires...so that makes no sense to me. Is this normal or is that switch bad? In the DIAG/TEST menu, it registers the cannon is at it's home position.
All of the soldering looks to be good. I will try moving the wiring around and seeing if that makes it come back to life. That would be a nice simple fix. Is there any way that I can check power to the motor itself when it is actuated? I think it runs on 50v. That way I could rule out everything else and see if it is just a bad motor. If I disconnect the cable to the cannon motor itself and hook up a meter and then actuate the motor, would that work?
