(Topic ID: 94990)
Batman Forever ~ Batwing shooter issues...
By MrBellMan
9 years ago
  • 6 posts
  • 4 Pinsiders participating
  • Latest reply 5 years ago by fcs1965
#1 9 years ago
I have an issue on my BF. When the Batwing is loaded and starts to turn in order to shoot the targets, pulling the trigger on the gun handle does not shoot the ball right away. I have to pull the trigger two or three times. I also tried using the flipper buttons to shoot the ball, but the same thing happens. I know my gun handle switch is good because it launches the balls with one press when in the shooter lane and it tests good in the test menu.
Anyone else have this issue?
Thanks,
Rob
Robsgameroom.com
#2 9 years ago
Unfortunately you will have to take the batwing apart. There is a switch that has to register as it rotates to the right before you are able to fire. This prevents the batwing from firing too soon and causing damage to the ramp or wire form.
This is similar to the cannons on STTNG. If you Google this problem, you will see what I mean.
Not positive, but there may be a batwing test that as it runs will show you when this switch registers. You will likely need to adjust it so it registers quicker.
All else fails, you will just need to hit the shot as the batwing rotates back to the right.
#3 9 years ago
Thanks for the info!
I will check the switch and post my findings.
Thanks,
Rob
Robsgameroom.com
#4 9 years ago
I have the same problem.
1 month later
#5 9 years ago
I have the same problem as well. I would like to fix it. Can it be adjusted in the test or will I need to disassemble the bat wing?
4 years later
#6 5 years ago
Quoted from martinb30:
anyone know where the switch that has to be adjusted is? before i take batwing apart
Professor Pinball
$ 7,995.00
Pinball Alley
$ 24.95
Mitchell Lighting
$ 32.00
$ 17.95
$ 27.95
$ 5.00
$ 27.95
$ 18.95
$ 29.95
$ 50.00
arcade-cabinets.com
$ 27.95
$ 259.00
$ 50.00
arcade-cabinets.com
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/batman-forever-batwing-shooter-issues and we tried optimising it for printing. Some page elements may have been deliberately hidden.
