Quoted from BallyKISS1978:Finally got the bat signal projector installed.
Wow that’s so cool on high ceilings, looks awesome
Quoted from TonyScoots:Beautiful
Welcome to the Batman family!
Awesome, thank you!! Fun title, been eff'n up penguin for the last couple hours.
Nice. I have a similar projector, if not the same. I might move mine to the floor once I get the machine into the game room. I like the bigger bat signal image for sure...
Quoted from TonyScoots:Wow that’s so cool on high ceilings, looks awesome
Thank you! Yeah it definitely looks great on my high ceiling.
Quoted from SteelTigers:Awesome, thank you!! Fun title, been eff'n up penguin for the last couple hours.
Nice. I have a similar projector, if not the same. I might move mine to the floor once I get the machine into the game room. I like the bigger bat signal image for sure...[quoted image]
I would move the projector lower on the back of the back box in stead of on top.
My Penguin launcher has failed..... I cansee it trying to launch the ball..... but its hardly moving it. Is there a adjustment or fix or order a part...?
Quoted from JMCFAN:My Penguin launcher has failed..... I cansee it trying to launch the ball..... but its hardly moving it. Is there a adjustment or fix or order a part...?
Are you talking about the crane motor?
https://www.pinballlife.com/stern-batman-66-crane-motor.html
Quoted from JMCFAN:No the launcher that shoots the ball out of the trough
Problem solved....small screw in there blocking the plunger.... now to find where it came from....lol
Quoted from JMCFAN:Problem solved....small screw in there blocking the plunger.... now to find where it came from....lol
Awesome news, that's the penguin Vuk. probable a small screw from the crane or maybe a pop bumper
Quoted from TonyScoots:Awesome news, that's the penguin Vuk. probable a small screw from the crane or maybe a pop bumper
What is a Vuk??
Hello team! After installing my Cliffy's, while in multi-ball, it seems that I have been getting more of these double captured balls in the bat signal hole. One is back far enough to not trigger the switch. The second is in far enough to not want to be nudged out (even when smacked by a 3rd ball) but yet not triggering the switch. Anyone else experiencing it? See the pic. Not sure if Cliffy's related, or just coincidence. Granted it's not a huge deal. As soon as I drain the remaining balls, it goes into ball find and pops them out just fine.
Quoted from superdrummer20:Hello team! After installing my Cliffy's, while in multi-ball, it seems that I have been getting more of these double captured balls in the bat signal hole. One is back far enough to not trigger the switch. The second is in far enough to not want to be nudged out (even when smacked by a 3rd ball) but yet not triggering the switch. Anyone else experiencing it? See the pic. Not sure if Cliffy's related, or just coincidence. Granted it's not a huge deal. As soon as I drain the remaining balls, it goes into ball find and pops them out just fine.
Geez thats a pain. I have Cliffy's on my game too and have NOT had this problem. Maybe re-position it over the hole? Or you could just take it out and put mylar in that spot. Being that this is a high traffic spot, i would think waiting for a ball search would really mess up the flow of the game.
No problems here.
Looking at the pic on Cliffy's site, maybe, the protector from underneath is sticking up too high and the ball is not rolling forward onto the switch. If you softly roll a ball into the hole, does it roll back forward onto the switch? I suppose it may even be possible that the right side of the scoop has some play and could have shifted towards the center of the hole, causing it to restrict a slow ball roll back to the switch. Just throwing some ideas to check out there.
Quoted from JONESDS:No problems here.
Thanks for the thoughts. No real issues with the switch with just a single ball. It only happens in multiball, and I somehow magically get two in quick succession in the left orbit.
Quoted from TonyScoots:Upgrade time! Thank you Flip N Out
Reached out to them.... hope that have more....
I bought a Batman from Flip N Out that already had this apron installed, but I need to find one of these for my Elvira 40th. Once in hand, I’ll use the Batman decal as a template to put some new artwork together for Elvira (since it doesn’t look like we’ll be getting any help from Stern).
Wanted to show a side by side comparison. The IC one looks more darker in color and it also moved the seizure warning in yellow to the bottom plus they made the Batman logo smaller!
I switched it out but will see, I kinda like them both!
Quoted from TonyScoots:Wanted to show a side by side comparison. The IC one looks more darker in color and it also moved the seizure warning in yellow to the bottom plus they made the Batman logo smaller!
[quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image]
Why does the size look larger...??
Quoted from JMCFAN:Why does the size look larger...??
Ever caught a fish and held it closer to the camera to make it look bigger? I have.
They are the same size that’s just the angle of the picture I took
Quoted from TonyScoots:They are the same size that’s just the angle of the picture I took
Thanks Tony for the comparison photos. Was wondering the difference before making a purchase.
Hi, new owner. My right ramp was a bit loose. Seems like the spade bolt on the right side snapped. I take it this was a the offset one rather than the straight? Has this happened to anyone else? I have a rivet anvil so should be able to reattach or maybe a small bolt and nut?
Thanks Sutol for helping me out. It is the offset spade bolt. Happened to him as well.
I just saw a ad for a B66 PRe for 11-5>With topper.Anybode know what the LE are going for??With topper!
Quoted from hawkmoon:I just saw a ad for a B66 PRe for 11-5>With topper.Anybode know what the LE are going for??With topper!
If the archived ads are anything to go by, around 19k looks to be the average of asking prices.
For the Super LE, I seem to recall there were two runs. First one was 30 machines and the second one was 50 machines (or vice versa). How do you tell if a machine was part of the original run or the extended run? Not sure that it matters, just curious.
Quoted from bjorg:For the Super LE, I seem to recall there were two runs. First one was 30 machines and the second one was 50 machines (or vice versa). How do you tell if a machine was part of the original run or the extended run? Not sure that it matters, just curious.
The 50 years of Batman (1966 - 2016) and 30 years of Stern (1986 - 2016) were a single run. The plaque on the speaker panel will denote 50th Anniversary with the year, or 30th Anniversary with the year. There were also 240 LEs, 120 Gadgets, and 120 Episodes.
Quoted from TrixTrix:The 50 years of Batman (1966 - 2016) and 30 years of Stern (1986 - 2016) were a single run. The plaque on the speaker panel will denote 50th Anniversary with the year, or 30th Anniversary with the year. There were also 240 LEs, 120 Gadgets, and 120 Episodes.
Awesome. That's easy to determine. And thanks for correcting my faulty recollection on the production run!
Anybody have any suggestions - my auto plunge is launching the ball in the air and it’s catching on the wire form ramp. Turning the plunge power down works, but now I can’t get it all the way around. The auto plunger is obviously striking the ball wrong. Is there a way to adjust so it doesn’t send it airborne? Thanks!
Quoted from RobbyIRL5:Anybody have any suggestions - my auto plunge is launching the ball in the air and it’s catching on the wire form ramp. Turning the plunge power down works, but now I can’t get it all the way around. The auto plunger is obviously striking the ball wrong. Is there a way to adjust so it doesn’t send it airborne? Thanks!
Have you tried moving the playfield back and forth to align the plunger with the ball?
So I cannot get my game to update. It pauses for a second at 20, and then at 60 says "unpack failed." What do I do? I've redownloaded the code, reformated the USB to fat 32 a few times. I'm getting stone walled EVERY SINGLE TIME trying to update.
The stupid thing is, I was able to do a quick update before this.... I was getting the SD error, and was told if I did a full update that would work. Well, not my game has no data on it at all and needs an update (full is my only choice it gives me), but I simply cannot proceed.
Does this have to do with the SD card for some reason??
Quoted from Doctor6:Does this have to do with the SD card for some reason??
I would say Yes. I would try another SD card
Quoted from bicyclenut:I would say Yes. I would try another SD card
I bought SD card and am getting it Tuesday. I've seen videos where you flash the card on your pc, but, is there a way to put a blank one in and do it that way, or must it be flashed when doing a completely blank card?
Quoted from BallyKISS1978:Anyone put pinstadiums in their Batman?
Oh, yeah, from day one. I have Pin Stadium’s on most of my games, but not all. Batman 66 is one of the darker ones and really pops with Pin Stadium’s. I am also an old guy with crappy eyes.
Quoted from Doctor6:I bought SD card and am getting it Tuesday. I've seen videos where you flash the card on your pc, but, is there a way to put a blank one in and do it that way, or must it be flashed when doing a completely blank card?
You need to flash it from your computer and put the new code on it. Putting a blank SD card in wont do anything. Also make sure you are downloading the SD card image and not just the update from Sterns website.
This video should help explain the process:
Let me know if you need anymore help
Im sure this has been asked before but, anyone know the differences in the codes? As far as installing the SLE, LE or premium in your game. I have a premium with a Stern Villain topper with a intergraded Stern Bat signal. I know the SLE has custom call outs but that has to be done from factory right? I guess my question is, Am I going to run into problems if i install the SLE/LE code in my premium and/or if I install the prem code, will I lose my Bat signal? Thanks for any help.
Quoted from bicyclenut:Im sure this has been asked before but, anyone know the differences in the codes? As far as installing the SLE, LE or premium in your game. I have a premium with a Stern Villain topper with a intergraded Stern Bat signal. I know the SLE has custom call outs but that has to be done from factory right? I guess my question is, Am I going to run into problems if i install the SLE/LE code in my premium and/or if I install the prem code, will I lose my Bat signal? Thanks for any help.
They are all the same code.
Quoted from bicyclenut:I did this instead of buying another apron. Insider connected works great and i got to keep my volume controls
That's the only way I'll do IC on a machine not designed with it in the apron.
Quoted from TrixTrix:They are all the same code.
How does it work with the same code when SLE has specific call outs?
Quoted from Trekkie1978:That's the only way I'll do IC on a machine not designed with it in the apron.
I just bought the updated apron
This page was printed from https://pinside.com/pinball/forum/topic/batman-66-official-club-thread/page/364 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
