Quoted from Citizen69:I didn’t “re-seat” but I made sure all the connections that I saw were pushed in and seated. After inspecting the underside of the play field. I powered the game back on. The crane and turntable seem to be working but don’t last an entire game. Powered off the game. Gave the game several minutes to deplete the capacitors. Powered back on. Turntable starts to reset itself back the start position. Play another game. Crane and turntable functions still can’t last a whole game session. Powered off again. Several minutes later, powered back on. Turntable goes back to start position.
Check me if I’m wrong but this is starting to sound like a main board issue or code. Thinking about reinstalling 1.06 but not a quick install this time.
Thoughts?
If you're the only one with the problem it's probably not code.
Check for operator error messages in the service menu after things glitch out. You could have a bad node board, which you can troubleshoot by swapping similar node boards and setting dip switches on them accordingly (it's a bit of work but worth it if that's the problem). A full re-install of code might be a good idea with this type of quirkiness before heavy experimenting. Your initial errors sounded just like what my friend's game was doing when the carousel was out of alignment and couldn't turn, so I would try to verify that for sure before you do much else.
