Love the game, just seems odd that the nicer back-glass was omitted from the LE and SLE. And that the LE-style speakers were included only on the SLE.
Quoted from Dan1733:
SLE - $14,999 (two years ago)
wow....did not know that.... thats insane...
I think the LE translite is the best of the three.
I see a lot of you have added Hallmark ornaments to your game and they look awesome. I’ve gone through the threads to see what the best way is of attaching them but couldn’t find anything. What do you suggest as the best way to add the ornaments to the game so they don’t fall over?
Quoted from Jpbogart:
There's plenty of pics on this thread to show you how to attach the hallmark characters and toys. There's a few that are key posts as well. Here's the Catwoman link that is pretty popular. Most are attached by wire.
https://pinside.com/pinball/forum/topic/batman-66-official-club-thread/page/30#post-3581424
Quoted from AUKraut:
Left flipper cradle, then sharp backhand!
I trying too practice this shot....it seems like the flipper does not have quit enough power to make it consistently...
Is there a adjustment similar to Munsters? I cant seem to find it...?
Ok, I've been searching with no luck but I'm a new owner and the left loop switch seems to be in from the rail enough where not all shots trigger the switch. The switch is working fine but it doesn't seem like there is even a way to adjust it to improve the shot. Is there something I'm missing?
Quoted from JMCFAN:
Have you checked your coil stops? Bad coil stop can effect power.
Quoted from Waxx:
I'm sure I unscrewed the switch and reset it. Also make sure it is not catching on anything underneath too.
If it still doesnt register then remove it and bend the wire.
Lift the playfield get a ball and roll it round there and adjust as necessary. I had similar issues a good while back and I bent the wire I recall. Had no issues since.
Hope that helps.
Quoted from Sutol:
Hope that helps.
Sorry, hard to describe but I've added some photos. I am trying to make sure this is how it was designed and it appears yes. My switch works perfect but the way the switch sits in the lane the ball can miss the switch entirely it seems.
1st photo is a PF and 2nd is my game. Everything seems to line up.
Has anyone seen a post that would help me find the post that has the solution to my crane being off alignment?
From left, positions one, two and three are fine. Position four (second from right) is a notch to the right and holds the ball between the wreckin’ ball and the right side. The default position (all the way to the right) looks over too push. Notable because that spring bends from the depression.
Before you say, ‘pics’, I’ll post them once this Special K wears off.
In other words, I need to shift the crane position a jump to the left at the lock shot.
Quoted from Waxx:
[quoted image][quoted image]
Looks the same as mine.
Put it in switch test mode and manually run a ball round there.You'll probably find it doesn't register the switch completely when it hugs that side rail.
A bit of tweaking on that switch/wire and you'll get it working 100%.
You looked underneath yet?
Quoted from Sutol:
Yeah, I've been studying it and it looks right but top and bottom but doesn't seem to always register. I think you are right and I will probably continue trying to bend the switch to see if I can get it aligned better. I was just curious if anyone else has experienced this as it seems like it was oddly designed. I can't immediately find the flaw or solution which is rare after owning many pins over the last decade.
Quoted from desiArnez:
Try setting the Penguin Motor Lag adjustment to zero and power cycle the game.
Does anyone know the part# for the slingshot post in the below photo? I have to replace one and can’t find anything in the manual that would show the exact part#. I’ve gone to a couple of the parts shops, but they were only able to make a guess. I’ve got the clear plastic piece that the metal stud fits into and the nut that holds the slingshot cover in place. I’m having a hard time coming up with the stud post part# though. If anyone could help I’d REALLY appreciate the help.
https://www.pinballlife.com/data-eastsegastern-narrow-plastic-post-1-116-tall.html
Thanks. The plastic post I have. It’s the metal stud that fits into it that I need. I was hoping the part# would be listed in the manual but no luck.
Quoted from jfh:
I wish I could find one...been hell.
Quoted from Sutol:
I think I got it nailed. I wasn’t sure it would work but moved the switch as far left as possible. Then bent the rail guide a Little but out there. That seems to have done it.
Quoted from EightBallTexas:
That’s because Stern doesn’t allow the sale of an LE translite to non-LE owners. Doesn’t mean it’s impossible though.
SLE owners got all three translites; maybe you could convince one of them to sell you an LE.
Quoted from jfh:
If I could fine one....I am seeing if this Swizz guy can do something for me...He has 100's of custom items...
Quoted from jfh:
Same with the Catwoman ones you can’t get them I’ve tried to get one to frame.
Howdy folks,
Bought a used BM66 Prem a few months back, been in good shape til the other day. Snapped a rubber ring inside the rotisserie. Pulled the broken rubber but wondering if there's a way to open the assembly from the top and replace that rubber or if I have to take the whole assembly out from the bottom to get to that...
Any help would be appreciated. Thanks!
Quoted from Skipnatty:
Howdy folks,
All rings can be changed from the Top side no need to pull the assembly. Many pictures in this thread to guide you.
Quoted from Yelobird:
Very good news, thanks for that. Appreciate the quick reply.
Quoted from J85M:
Catwoman Edition is actually considered an LE, hence the same rules.
Orange County pinball posted that Stern will be doing a limited run of new Premium BM66 in November 2020. Good if someone looking get the machine new and potentially new code release coming.
Quoted from jfh:
They called it a Signature Edition but same difference. I don’t like the weird/bad Photoshop on the Catwoman translite though.
I'd email Stern. They should be able to tell you the exact part number.
Quoted from GoodOmens:I'd email Stern. They should be able to tell you the exact part number.
So devastated to hear about Chas! What are we going to do without him?! He was always so helpful and went above and beyond. I appreciated his help for this "newbie" and no matter how stupid the question, he was always so polite. What a loss for Stern and for their customers!
https://www.facebook.com/TopScoreGamerooms/photos/a.567304403315505/3149103505135569/
Light the turntable?
My eyes are shot. Somehow it makes me a better player...
The turntable is impossible to distinguish details in the shadows (with my affliction) and while I have Comet spotlights on the playfield, I just can’t see the shots On the turntable very well.
I’d love to wire in some little lights pointing downwards under the batphone, TV, etc.
Imagine a pinner white LED illuminating the batphone shot wired off the batphone light.
Anyone ever try this? Any advice other than, ‘if it ain’t broke, don’t fix it.’
(Posted in the wrong thread.) Someone was wondering the reason why Batman 66 TV series was taken off the air after only 3 seasons.
The networks all loved the huge success of Batman66 TV series. It only went off air because of all the lawsuits and entanglements from major companies all claiming soul rights to it (DC Comics, 20th Century, ABC, Warner Bros, Greenway productions and Disney to name a few, lol) because it was so hugely successful. They tied it up in courts for many years.
Every actor in Hollywood wanted to do a cameo or appearance on it. It would have gone 10 seasons without all the lawsuits and is the very reason why it took so long to get it released on DVD.
Our Bat66 machines are a trophy to that show and is a big collector item amongst the many Bat66 fans worldwide. Here’s hoping when Stern runs the next batch at the end of the year, Lyman adds some of the rumored features to it. Although the code is awesome the way it is for sure. Would love some more light show and grand wizard mode after going through all the main villain chapters. A wall walk of fame mode is wishful too.
Still enjoy watching the TV series. It was a quality production and still holds up today.
Robin shown on the link saluting Green Hornet and Kato (Bruce Lee). 2 dynamic duos to another 2 dynamic duos, lol.
https://lh4.googleusercontent.com/proxy/NVgeXkXBUwuCqBbi6Tu5LogWAcjynqwlBkQ9WHqDsYmm-eyx6CWrzdzbm4Co3SZtJ-v5HxEzhqfECFSOgDk5wkQJbu8FpUXy1dtUDsliQUs26s9J0vAct64d-T88G7YdVhbdQV43zJjL_AqY1YNFSUAjfg=w411-h358
Quoted from Thunderbird:
The networks all loved the huge success of Batman66 TV series. It only went off air because of all the lawsuits and entanglements from major companies all claiming [sole] rights to it (DC Comics, 20th Century, ABC, Warner Bros, Greenway productions and Disney to name a few, lol) because it was so hugely successful. They tied it up in courts for many years.
Umm, no.
ABC was losing money after the first season. The movie did not goose the series as much as expected for season two. By season three the budget was cut significantly and the ratings dropped quite a bit. It is rumored NBC wanted to pick up the series but didn’t do so because the sets (primarily the Batcave) had already been dismantled/destroyed and they didn’t want to pay to rebuild them.
The lawsuits you mention involved the home video rights, not the original production rights. And I’m pretty sure Disney wasn’t involved.
You are correct about the guest stars - Batman was a red-hot phenomenon for about a year and a half and many did want to appear on the show.
Quoted from jfh:
Umm, no.
Lots of Bat-scholars think that NBC wanting to pick up the series was a myth that got started in a book about the show and then some of the cast started repeating it. People have scoured the records of producer William Dozier and others but no evidence of NBC or a 4'th season intent was ever found.
Dozier was known to be very money savvy and after the ratings were steadily declining by season 2 he started thinking about syndication. You couldn't syndicate an active show and you wanted at least 100 episodes. So season 3 was done as cheaply as possible just to get to that minimum 100 episode mark. Dozier knew the show could make a lot more money once it was syndicated to local stations all over the country. The ad below was put in the trades in Feb 1968 to start selling syndication while the 3rd season was still going on.
A big part of the second season decline was the new color season of Lost in Space which was a big hit on Wednesday nights. Part 1 of Batman was also on Wednesday's with part 2 on Thurdays. So people would skip part 1 of Batman and watch Lost in Space instead. Then they would just watch Batman part 2 on Thursday since it included a nice recap of part 1 at the beginning of the episode.
Lots of info on the 4'th season myth here.
Quoted from adborto:
Does anyone have and details on the next run? Is it the final run? Another special edition maybe?
I don’t have any details, but I doubt there would be another special edition like Catwoman. It didn’t sell that well (though because of that everyone ended up with an autographed card from Julie). Also, I thought dealers already had the last call on Batman 66 orders but may be mistaken.
The flyer and LE COA has some great artwork on them so I thought I would frame them and hang them up in the gamesroom. Something a little different from the usual backlit translites I’ve got.
Flyers signed by George and Lyman to add that finishing touch!
Quoted from J85M:
Cool idea. I wish I had the wall space to do something similar.
Consider getting a corrected flyer (that has the correct head art) for the front display.
Quoted from jfh:
Didn’t even know they had released a corrected flyer with the batgirl side art.
The final run was Spring 2019. Here is the advertisement from that announcement last year...
Quoted from wrb1977:
The final run was Spring 2019. Here is the advertisement from that announcement last year...[quoted image]
This was what I saw posted on Orange County Pinball Instagram
Quoted from J85M:
https://sternpinball.com/wp-content/uploads/2018/10/BM-LE-Flyer_65.pdf
Quoted from Homebru:
Could someone please tell me where/how this is intended to be installed?
In the bin! Lightedpinballmods are some of the worst mods in this hobby.
Bin it and grab yourself docquest bat signal mod.
