(Topic ID: 167576)
Batman 66 - Official Club Thread
By TigerLaw
5 years ago
  • 17,007 posts
  • 678 Pinsiders participating
  • Latest reply 40 minutes ago by TonyScoots
  • Topic is favorited by 257 Pinsiders
47 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 17,007 posts in this topic. You are on page 271 of 341.
#13501 2 years ago
So, got a " Slam Tilt" reset the other night..Ended up power cycling as it never came back up properly.
Guess I haven't paid attention, but switch certainly isn't on coin door...Any thoughts, as I didn't even nudge when it happened
#13502 2 years ago
Ok, its in the house. The only damage to the box is that little wrinkle in the bottom corner of this pic.
I’ll report back later.
#13503 2 years ago
Quoted from docquest:
If you have the LE/SLE topper with the ceiling projector, that lights up under those conditions.
I don't have the topper or a LE/SLE, but I did add in the bat search light to the existing supplied hookup for it. In my mind I thought for some reason that although the orange arrow indicator is lit on the left orbit, being the screen is saying shoot for the bat signal at least the batman logo in the sky from the light would be lit or even the bat signal search light itself. I guess it's as Thundergod76 stated maybe this will be something addressed in the up coming code release when Lyman does some more polishing.
#13504 2 years ago
So i am about 30 minutes into my first plastic protector for the left/right slings. Anyone have insight?
It appears that I need to remove the dome and led strip below it? It wont unscrew. I’ll keep trying.
Edit: got em on. Now on to cliffys, inner side art, or headphone kit.
#13505 2 years ago
I could use some insight on installing the penguin scoop cliffy.
#13506 2 years ago
Looks like i have a tiny chuck torn up on my playfield.
#13507 2 years ago
This is the kind of stupid shit that has been happening all day. Either the bolts sent with the shaker motor are 1/4” too short, or I need to move this ground strap, from under where it appears the shaker motor goes. Honestly I may need longer bolts anyway. When I drop them in their holes for testing, 1 or 2 turns and they are tight. When I attempted the shaker motor install over the ground strap, only 1 bolt would tighten. The other 3 spun freely.
#13508 2 years ago
I had some longer bolts on hand and went with those.
Any reason I would need this conn3ctor with a capacitor ?
#13509 2 years ago
Quoted from TronGuy:
This is the kind of stupid shit that has been happening all day. Either the bolts sent with the shaker motor are 1/4” too short, or I need to move this ground strap, from under where it appears the shaker motor goes. Honestly I may need longer bolts anyway. When I drop them in their holes for testing, 1 or 2 turns and they are tight. When I attempted the shaker motor install over the ground strap, only 1 bolt would tighten. The other 3 spun freely.[quoted image]
You don't need to move the ground strap. It's probably there on purpose for grounding.
Rob
#13510 2 years ago
Ok, I’ve owned the game for 8 hours. It is time to power it on. Got the side rails, most cliffys (gotta do the shooter lane still), plastics, inside side art, crane add on, speaker kit. Maybe more, I’m tired. Gonna play for a bit.
How d9 I set it for freeplay?
09FF1AD1-C85C-4CDD-8F16-6A9B92FDEF6A (resized).jpeg327EA213-216E-413F-9606-1779423D0B2A (resized).jpeg96CDA632-79A7-48EB-AB8F-E38E9F8B760D (resized).jpeg9D0B4B9E-4BA5-454A-9937-52936DC6E8FF (resized).jpegA981971F-2A06-4291-921D-1FA892B9B242 (resized).jpeg
#13511 2 years ago
Any reason I would need this connector with a capacitor ?[quoted image]
May be one of the fix kits that wasn’t installed at the factory. Guessing the shaker motor one (and you don’t have a shaker motor). See if you have one inline to the shaker motor (if you have one) and see service bulletin 184.
Could also be an uninstalled one for the node board fix kit.
#13512 2 years ago
I installed a shaker motor. It does not currently any capacitor, diode, resistor between it and its connection to power.
#13513 2 years ago
Here’s a picture of where the capacitor goes on the board on the side of the cabinet from the shaker... (sorry it was quick and dirty).
#13514 2 years ago
It is specifically recommend by Stern to address electrical noise on the 48v power source.
Notice: When using the Genuine Authorized Stern Shaker Motor Kit #502-5027-01 on Spike 1 and Spike 2 system games, it is required that the Cabinet Node Capacitor Kit be installed. This additional capacitor prevents mysterious SLAM TILT switch activations from occurring.
https://sternpinball.com/wp-content/uploads/2018/08/Stern-ShakerMotorAdvisory.pdf
#13515 2 years ago
Looks like i have a tiny chuck torn up on my playfield.[quoted image]
Damn. I'd be pissed.
On a side note, I'm totally jealous. I haven't gotten mine yet. When did you order?
#13516 2 years ago
OK,this is the first one I've seen,and no pics of the backbox art!!also a Julie Newmar signed Batman Card! So,Stern could possibly put out a Joker,Penguin,Riddler,model with accompanying signed cards!!And by the way,TronGuy,a lot of us got our games totally fubar,right out of box!! I couldn't play mine for three weeks after it arrived cause the turntable was totally broke,among other things!!! Good to see Stern still has NO QC at all!!!! Go Stern
#13517 2 years ago
I'm confused by this pic. My Batman and my Ghostbusters, for that matter, had the entire inside of the cab sprayed black. You seem to have no paint on your bottom panel. Guess Stern is using multiple cab mfgrs.
#13518 2 years ago
Quoted from RC_like_the_cola:
all of my NIB sterns have been painted black on the inside (even my previous BM66) but my Catwoman edition is the first I've seen with the raw wood bottom on the inside.
#13519 2 years ago
Quoted from RetroGamerJP:
all of my NOB sterns have been painted black on the inside (even my previous BM66) but my Catwoman edition is the first I've seen with the raw wood bottom on the inside.
I believe when stern was using press boards on the bottoms they were painted black, now with real wood they are left natural. I guess they are trying to say "Hey look, we are increasing our build quality" statement.
#13520 2 years ago
Quoted from hawkmoon:
Given that Romero, Meredith and Gorshin can’t sign any more, probably not ...
#13521 2 years ago
I will get a pic of the side art. The backglass has some fine print saying something to the effect of:
CATWOMAN SIGNATURE EDITION
#13522 2 years ago
Just ordered my first NiB - Catwoman signature series. The family is excited! Can’t wait to get it
#13523 2 years ago
Im curious, for those who have the Catwomen edition, do they all have signed cards by Julie Newmar? Or is it just a select few? Also, did they take the catwomen scenes out that have Eartha Kitt in them?
#13524 2 years ago
Quoted from bicyclenut:
The first 100 were to get autographed cards.
#13525 2 years ago
From 2 pages back...
https://pinside.com/pinball/forum/topic/batman-66-official-club-thread/page/269#post-5030748
#13526 2 years ago
Quoted from Happy81724:
It’s the Catwoman Premium.
They had her sign cards in 100 of them - so don’t be bummed if yours has no signature.
I would hate to see the pinball hobby fall to the “I bought it because it was signed by a B list celebrity” level ...
Oh wait ... maybe we are already there ...
Actually ... it was funny a few years back. Gary Stern came to NZ and was at my place. He had some signed translites to give away - the local Stern guy said “do you want Gary to sign your games?”
“Ummmm ... no ... not really”. Lol
I did win a TWD translite though!
rd
#13527 2 years ago
How d9 I set it for freeplay?[quoted image][quoted image][quoted image][quoted image][quoted image]
What method did you use to install the inside side art? Did you remove the playfield?
#13528 2 years ago
Quoted from DeathHimself:
Or maybe it has to do with UL certification.
Rob
#13529 2 years ago
Quoted from beefzap:
No, I an a risk taker. I cleaned the sides of the cab with some rapid tac and a paper towel.
Then I pulled the backing off of the pinblades and sprayed the sticky side pretty heavily with rapid tac. Shoved them in the cab with the playfield down and figured it out. I had a hand squeegee ready when needed to flatten the art. At least twice on both sides I yanked it up after 5 minutes because I wasn’t happy with the placement. Another spray down of rapid tac and back in it went.
#13530 2 years ago
Quoted from rotordave:
rd
Yep, all preference and the signature for the same price did influence me buying it. I was going to get one anyway so i bought it a little sooner than planned. If they charged more for the signature I would of just bought the standard.
I made sure it was the 100 of the Signature series. It’s not my first pin just my first NiB.
#13531 2 years ago
What does this mean?
#13532 2 years ago
Technician alert on 1 ,8,9,10 not initialized.
#13533 2 years ago
Oh yeah, pic of back box .
#13534 2 years ago
I also have an : OPERATOR ALERT
TOP EJECT DEVICE MALFUNCTION
The ball isnt registering up in that top scoop.
#13535 2 years ago
Sounds like maybe a larger molex isnt seated properly.
#13536 2 years ago
Quoted from thundergod76:
In the back box I assume?
I’ll check.
I fixed the rear captive ball. The way I installed the tiny square cliffy may have been off. I tweaked the lever to the microswitch as well as installing that cliffy a little better.
#13537 2 years ago
Have you reported this to Stern. This would be a big deal to me.
#13538 2 years ago
I sent a picture to classic game rooms (place I bought it from). ignored. He responded to other things.
Maybe this will be obvious to some, but the node boards not responding is because the coin door was openwhich shuts off some HV. When I pulled the interlock (with coin door open), all was back to normal.
#13539 2 years ago
Strange... Does your game have an interlock switch? They removed those switches starting with GOT. My friends Batman does not have an interlock.
Please post a picture of it. Did it came that way from factory? Whats your build date?
#13540 2 years ago
For those modders who want a catwoman hallmark ornament the ornament factory is doing a 33% off sale with code "SUMMER33". It says they have limited quantity of catwoman left. The discount gets the pre-shipping price down to about $24 which is less than what you usually see them for on ebay.
https://www.hallmarkornaments.com/2016-CATWOMAN-Batman-LIMITED-QUANTITY_p_23454.html
Heres a detailed post on how to light up the diamond her hand.
https://pinside.com/pinball/forum/topic/batman-66-official-club-thread/page/30#post-3581424
#13541 2 years ago
https://pinside.com/pinball/forum/topic/batman-66-official-club-thread/page/30#post-3581424[quoted image]
Keeps showing in stock then when adding to cart it's out of stock.
But they do have the Riddler in stock:
https://www.hallmarkornaments.com/2018-The-Riddler-Batman-LIMITED-EDITION_p_24801.html
#13542 2 years ago
I found that removing the playfield makes it much easier to install the pin blade art. I pretty much watched the below video and did exactly as shown. It was really easy-
#13543 2 years ago
Quoted from Midway-Man:
I can’t find it now , but I thought I saw a build day of may, 2019.
#13544 2 years ago
It's on the back of your lower cabinet not the backbox. My machine has a build date of Aug 2018 and no interlock switch.
#13545 2 years ago
A game like BM66 probably should have a safety interlock switch so the turntable doesn't move and hand cause injury. It's also a PITA troubleshooting some switches in test mode because coils stay active (balls release etc).
Rob
#13546 2 years ago
Same here. Finally showing out of stock now. I went to lunch, then came back to see this and was gonna grab one. Grrr.
#13547 2 years ago
You might be able to get riddler cheaper on ebay. Catwoman seems to be the one that's is getting harder to find at a decent price.
This fall they will be releasing Batgirl as well as the Batboat.
#13548 2 years ago
This may be a dumb question, but did Stern have those cards rerun or did they shell out for a bunch of sealed sets of 30 year old cards? I've been researching and these cards were reissued in 1989.
#13550 2 years ago
Last call. If you’re on the fence about getting a game, contact your distributor.
All Catwoman Edition games will include a signed card, not just the first 100.
