(Topic ID: 167576)
Batman 66 - Official Club Thread
By TigerLaw
2 years ago
  • 13,039 posts
  • 474 Pinsiders participating
  • Latest reply 40 minutes ago by Decimal
  • Topic is favorited by 185 Pinsiders
There have been 2,704 images uploaded to this topic. (View topic image gallery).
45 key posts have been marked in this topic, showing the first 20 (Show topic index)
There are 13039 posts in this topic. You are on page 243 of 261.
#12101 3 months ago
Sounds like a call to your distributor and/or Stern on Monday morning will be needed....
#12102 3 months ago
Quoted from thundergod76:
Most likely the board is bad and needs replaced. This tends to happen too frequently right after an update to the fragile Spike system. Does this board have the Stern service bulletins applied to it? https://sternpinball.com/support/service-bulletins/ Curious to know if these fixes are helping at all.
Yes it has been attached.
#12103 3 months ago
Going to try reinstalling the code.
#12104 3 months ago
I'd check the D9 diode on Node board 8 and see if one of the leads has broken off the board. This seems to be the culprit more times than not.
#12105 3 months ago
That looks fine too.
#12106 3 months ago
Does anyone know how the firmware on a particular node board gets updated when a new board is swapped in? Is a check done at power up and the node boards updated or does something else need to be done?
#12107 3 months ago
Quoted from jfh:
I assume it happens automatically at power up. When you download the code it's getting loaded to main board then after you power cycle it does a check and if any of the node boards are not up to date it programs them appropriately.
If you put a new node board in make sure you set the dip switch settings on the new board to the proper setting (use old board for reference). Not doing may prevent the board from updating properly.
#12108 3 months ago
Quoted from Damien:
Appreciate you taking the time to send me all of that.
I was considering buying one on the resale market, but maybe knowing all of this, I'd be better off looking at NIB.
Have the soft/dimpling pf issues been addressed?
And what is the atomic pile? Is that a mod, or some changes they made to the turntable?
Also, I'm curious to know if this is a longer or shorter playing game. And what other game(s) you would say that this game feels and plays like in respect to flow and code.
There aren't many BM66 on the resale market, especially here in Canada. NIB certainly has advantages since you will have all the latest tweaks to the game. I bought mine in November and it had an October 2018 build date. I can say without a doubt this is one of the BEST games I have ever bought. Theme integration is second to none. Sound and music are also fantastic! It shoots a heck of a lot better than it looks, the shots are fun and rewarding. It is an amazingly fun game!
Rob
18
#12109 3 months ago
It’s here!
#12110 3 months ago
Quoted from WhiskeyTango:
It’s here!
Welcome to the club!
Now unbox that badboy!
#12112 3 months ago
Hey gang - I’m habing a somewhat odd problem and I thought I’d run it past the group.
When I answer the phone the ball kind of sticks on the magnet. It is not released until a ball search is done or I give the game a gentle push (not a hard push mind you, just a soft nudge).
I had silver jets in the game, so I took those out and replaced them with standard new balls just in case they were slightly magnetized...this did not solve or reduce the issue at all.
Any ideas? Anyone else expierence this?
#12113 3 months ago
Quoted from TigerLaw:
If you have a sticker on a magnet this happens fairly often......mine does it as well, hanging on the ModCouples' sewer sticker.
#12114 3 months ago
Sort of on topic.... Found this Life magazine from March 1966 at my local record shop. Made a custom frame for it and hung it up in the game room.
No Batman pin in the house though....
#12115 3 months ago
Quoted from AUKraut:
Agreed....getting away from silverjets a good idea anyway on this game....my sticker still looks kinda cool, but will definitely hold the ball a bit if the magnet gets a square hold on it.
doesn't really bother me, but pretty predictable...
#12116 3 months ago
Quoted from Foo:
I will never forget the day I was sitting at the kitchen table - I was 8 or 9 - and my mother brought in the mail with this issue and handed it to me. She couldn’t get over Batman being on the cover. I’m sure she thought it was beneath the usual standards.
Pretty sure the was an issue of TV Guide around the same time with Batman on the cover too.
#12117 3 months ago
I have the Mod Couple sticker on my game too but have never had a problem with the ball sticking. But I also have a playfield protector on.
#12118 3 months ago
I have no sticker, it’s stock, but the ball still sticks. Any other ideas or any fixes? Thanks!
#12119 3 months ago
Is the magnet smooth or does it have a lot of dimples? Wondering if it’s getting stuck in a divot or something like that.
#12120 3 months ago
Quoted from pintechev:
It does have a few dimples. It’s not perfectly smooth. I’ll look at where the ball is sitting because the dimples are not centered.
#12121 3 months ago
I had this issue one solution I found was simply removing it, however it does look pretty cool, so using one that covers the entire magnet area seems to stop any hang ups.
The image doesn’t appear to be custom made, as I found one on google which I’ve included in this post below so you can print out your own.
#12122 3 months ago
Here 's one for all you LE owners=My Batsignal went out yesterday,and I took it apart to see what kinda bulb it took! When I finally got it apart,the "bulb" was a sealed unit inside a small piece if white plastic with ridges on the side!! There is no way to replace this as no one has ever seen any thing even close to this!!! Chas at Stern didn't even know what the heck it was!!Apparently,the SLE and the LE are different!!!Waiting on Chas to see what he can do!! So,beware if yours goes out,maybe a hassle to fix!!!
#12123 3 months ago
What about a small piece of mylar for the hole in the middle?
#12124 3 months ago
Quoted from hawkmoon:
Maybe you could check the voltage on the socket while it's on and replace the existing with a new socket and an easier to source bulb?
#12125 3 months ago
I gave up on Sterns shitty Bat Signal long ago and went with Doc's. Much better IMO. Hope your issue gets resolved though.
#12126 3 months ago
Quoted from J85M:
For clarity, there is No decal on the actual center core of the magnet. It only covers the metal outer steel perimeter. The sewer decal And the protective Mylar are both donut cut in the center as you would never want a decal on the magnet core itself.
#12127 3 months ago
I gave up on Sterns shitty Bat Signal long ago and went with Doc's. Much better IMO. Hope your issue gets resolved though. [quoted image]
I found this alternative projector on amazon for just $15. Plus, you get two at that price. It's small enough to fit through the top access hole. It did require a 12vdc converter. Not the series-correct emblem, but works fine (and looks better.)
amazon.com link »
#12128 3 months ago
That's pretty cool! Not sure I'd want to drill a hole in my car door though.
#12129 3 months ago
Quoted from RTS:
I found this alternative projector on amazon for just $15. Plus, you get two at that price. It's small enough to fit through the top access hole. It did require a 12vdc converter. Not the series-correct emblem, but works fine.
amazon.com link »
OK I'll ask first. What 12 vdc converter did you use?
#12130 3 months ago
Quoted from crwjumper:
This one:
amazon.com link »
I cut off the connector at the end of the wire (the non plug end) and spliced/soldered it to the led projector's wires.
Install instructions are courtesy of docquest. Using the relay he recommends, you can make the projector interactive with game-play by tying it into a flasher if you like. Full details are here:
https://pinside.com/pinball/forum/topic/diy-tutorial-batman66-bat-signal-projector#post-4090106
#12132 3 months ago
Quoted from jfh:
I have a few questions...
How much of a PITA was the playfield protector to install?
Did you have to adjust any switches after the install?
Does it affect play at all?
How does it look?
I have a BM66 on order and have contemplated on getting a playfield protector.
Thanks in advance.
#12133 3 months ago
This topic comes up every now and then. I've had my machine just over a year now. After 2 weeks my balls were getting stuck on the sewer magnet as well. You mentioned you replaced the balls. I don't know what kind but these worked for me. https://www.marcospecialties.com/pinball-parts/PB116-5 It states....."Resistant to residual magnetism and exceeds factory specifications for hardness, roundness, and weight." I haven't had a single hangup since using these.
#12134 3 months ago
Quoted from RTS:
amazon.com link »
Nice! Did you buy the 12volt VDC converter from Amazon too? Where did you plug it in at on the back box?
#12135 3 months ago
Finally out of the box and updating code.
I've also started with the mod orders:
- The Mod Couple - Batman 66 Sewer Magnet Protector Mod kit (I'm actually on the fence about installing this now..)
- The Mod Couple - Batman 66 Custom LED Batphone Upgrade
- The Mod Couple - Batman 66 "KaPOW" custom shooter plate!
- Pinball Life - Batman '66 Art Blades
- The Modfather - Batman 66 Premium Pincup
#12136 3 months ago
Thanks all for your suggestions!!! upon further investigation,the led bulb is ok! The 5v to 12v convertor failed!! Stern part no.520-6975-00,none in Stern stock,so waiting on PBL to come up with it!!
#12137 3 months ago
Hay whisky tango,better open up that wallet a little more with the Mod-Couple's Atomic Pile and BatCave upgrade!! Worth it IMHO
#12138 3 months ago
Quoted from MadPole:
How does it look?
If I remember it took about an hour. Toughest part was figuring out what to do with the crane. It wasn’t bad. Not like some games where you have o take off half the playfield. The biggest mistake was waxing the playfield first as the wax reacted some with the protector. The resulting small spots/cloudiness in some areas isn’t bad (and my wife doesn’t see it) but annoying because I know it’s there. There is a thread on the protectors that details better prep steps. Some day I will remove this one, clean the wax residue and install a new one.
Didn’t have to adjust any switches. If you are going to do cliffys, put those on first. I had the original cliffy for the 2008 Batman installed prior and te Penguin hole shot is a bit tight. The version for BM66 apparently fixes this.
If it does impact play,it doesn’t bother me. I’ve always thought it is faster, but that may be my imagination.
Other than the fallout from the wax, I don’t think it looks bad at all. Most people haven’t noticed/commented that it’s there. It is certainly far less noticeable than I expected and I don’t even think about it any more except when the light hits a particular wax spot. It’s been on for just about two years and it still looks great.
A protector is probably overkill but I got an early game and had no idea if I got one of the super soft playfields and didn’t want to wait and see it damaged. It’s also an LE so I wanted to protect the signatures. I’m sure I could get an NOS PF but it wouldn’t have the sigs and that would bug me.
#12139 3 months ago
How could you pass on the Mod Couple Atomic Pile mod? If there is one “must have” mod, that’s the one!
There are other options for the phone upgrade. I prefer the toy bat phone on the cake plate version, but there are advantages to the MC phone mod
#12140 3 months ago
Where can I acquire one of those? Looks awesome!
#12141 3 months ago
I got them in my pinball shop along with a few other batman 66 mods I've made:
https://pinside.com/pinball/market/shops/1120-docquest-pinball-mods
#12142 3 months ago
Out of the box it plays ok, but that damn wire for the Cat Light above the left ramp. It was completely in the way and wouldn't allow a ball to pass through the orbit and I've been messing with it trying to get it to stay in place. I also need to increase the angle a bit as its a little shallow.
#12143 3 months ago
Quoted from jfh:
I haven't..
Here is my "To Be Ordered" list as of tonight
- Pinball Life - Stern Factory Authorized Shaker Motor Kit for Stern SPIKE & SPIKE 2 System Games
https://www.pinballlife.com/stern-factory-authorized-shaker-motor-kit-for-stern-spike-spike-2-system-games.html
- Pinball Life - 'Real Knocker Kit For Stern SPIKE/SPIKE 2
https://www.pinballlife.com/real-knocker-kit-for-stern-spikespike-2.html
- MezelMods - Batman 66 Pinball Crane Upgrade Kit
https://mezelmods.com/collections/batman-66-pinball/products/batman-66-pinball-crane-upgrade
- MezelMods - Batman 66 Pinball Siren Dome Covers
https://mezelmods.com/collections/batman-66-pinball/products/batman-66-pinball-siren-dome-covers
- MezelMods - Batman 66 Pinball Backboard Building
https://mezelmods.com/collections/batman-66-pinball/products/batman-66-pinball-backboard-building
- The Mod Couple - Batman 66 Batcave Spinner Upgrade Kit Complete with mounting disk!
https://themodcouplepinball.com/collections/stern-batman-66-custom-mods-collection/products/batman-66-batcave-spinner-upgrade-kit-complete-with-mounting-disk
- The Mod Couple - Batman 66 Custom Atomic Pile Mod Kit Lighted!
https://themodcouplepinball.com/collections/stern-batman-66-custom-mods-collection/products/batman-66-custom-atomic-pile-mod-kit-lighted
- The Mod Couple - Batman 66 Bat-Computers Upgrade kit!
https://themodcouplepinball.com/products/batman-66-bat-computers-upgrade-kit
- The Mod Couple - DocQuest Mini Bat-signal Interactive Game playfield mounted
https://themodcouplepinball.com/collections/stern-batman-66-custom-mods-collection/products/docquest-mini-bat-signal-interactive-game-playfield-mounted-batman-66
It looks like the speaker lights are no longer available, which is a real bummer. FWIW, I'm also looking into legs & rails, but then I'll need to send it all out to be powder coated.
#12144 3 months ago
Ok whiskeytango you are good to go!
Not sure the real knocker kit adds a lot and I still haven’t installed the siren dome covers because it seems out of place to have two when the Batmobile only has one but the rest are primo.
I sold my speaker light kit because I didn’t like the look as much as I thought and went with a couple of docquests logo magnets instead. I don’t think they distract from the TV effect as much.
#12145 3 months ago
Looks like the speaker lights are still available. Not for everyone but I absolutely Love these. Happy modding!
https://pinside.com/pinball/market/shops/1080-the-mod-couple/01339-batman-66-sle-premium-speaker-illumination-kits
#12146 3 months ago
I thought they had fixed it on newer games. Of all of the tweaks to my game dressing that cable was the biggest PITA.
#12147 3 months ago
I have been trying to resist ordering this kit, I love the way it looks but I am saving for another machine so I need to back off on the mods
#12148 3 months ago
Quoted from jfh:
I sold my speaker light kit because I didn’t like the look as much as I thought and went with a couple of docquests logo magnets instead. I don’t think they distract from the TV effect as much.[quoted image]
Good points on the knocker and siren dome covers. I've pulled the knocker from my list and will probably do the same with the dome covers.
I'm on the fence about what to do with the speaker lights and may go with a more subtle route as there is a lot going on already.
#12149 3 months ago
yelobird are you able to make these speaker kits in different colours or colour changing?
#12150 3 months ago
Anyone know of any distributors that might still have an LE or SLE? I know it's a long shot.
Or if anyone in Canada has one they'd be willing to sell, please get in touch.
$ 150.00
Lit Frames
$ 27.25
The MOD Couple
Blandon, PA
$ 16.50
Pinball Photos
$ 99.99
$ 7,599.00
Classic Game Rooms
$ 60.00
Docquest Pinball Mods
Filament Printing
$ 7,599.00
Operation Pinball
$ 7,599.00
Little Shop Of Games
$ 14.00
Pin Monk
$ 48.00
$ 24.25
The MOD Couple
$ 99.00
$ 48.00
$ 26.50
$ 129.95
Hookedonpinball.com
