Got my first billion on .84 tonight. All the way through Penguin with 'to the batcave' bump added. Bat Turn once, Mr Freeze once (didn't complete) and Egghead once (didn't complete).
Such a fun game.
Such a fun game.
Quoted from BrewinBombers:Got my first billion on .84 tonight. All the way through Penguin with 'to the batcave' bump added. Bat Turn once, Mr Freeze once (didn't complete) and Egghead once (didn't complete).
Such a fun game.
I thought I had the most current code but I am only running .83 is it worth updating?
Such a fun game.
SWEET!!!! I finally broke 1 billion 2 days before the last code drop.......this game is too fun!!!
Quoted from Concretehardt:I thought I had the most current code but I am only running .83 is it worth updating?
Yes/ Yes!!!
Quoted from MK6PIN:Yes/ Yes!!!
Quoted from pauloz:I’ll second that with a f$&@ yes!
Ok just did some reading and now it makes sense as to why I couldn’t figure how to get the channel changing mode to work, I will be updating to .84 ASAP.. thanks guys
EVERY update is worth installing!
Quoted from Concretehardt:Bat signal topper mod installed (very cool)
Does the bat signal topper come on at certain times in the game or is it just always on? Was considering the Stern one, but it’s not cheap.
Quoted from spandol:Does the bat signal topper come on at certain times in the game or is it just always on?
It is on during attract mode, parachute pickup mode and when the Batphone is ringing.
Quoted from jfh:It is on during attract mode, parachute pickup mode and when the Batphone is ringing.
That sounds cool. Thanks for the info! Was considering for my premium that’s coming.
Quoted from spandol:That sounds cool. Thanks for the info! Was considering for my premium that’s coming.
The game control signal is only available with the LE/SLE (uses the the boards that run the topper) (if I remember correctly).
But it's still a great mod to have for a Premium (Doc's mod)
Quoted from spandol:Does the bat signal topper come on at certain times in the game or is it just always on? Was considering the Stern one, but it’s not cheap.
Forget the Stern Bat signal and buy docquest's Bat signal mod. Better quality for a lot less!
Quoted from thundergod76:Forget the Stern Bat signal and buy docquest's Bat signal mod. Better quality for a lot less!
so true!
Awesome, thanks!
Yep that’s what I am running, super easy install on the LE.. thanks Doc!
Is there a consensus on the best joker target fix? Mine started getting stuck again.
Edit: Dead foam centered on the bracket behind the target where its getting stuck works like a charm so far! All this non work free time is killing me
Time for Santa suit and a little Egg nog. Merry xmas!!!
Quoted from Concretehardt:My cabinet corners look perfect so I figured I would be proactive and reinforce them with the upgraded brackets.
Very nice....I've been guilted enough....mine are perfect too, but adding the heavy brackets next week, to be safe....
Quoted from kidchrisso:Where are you guys buying the brackets from?
Pinball Life has them.
I need to do this too. Did you do all 4 or just the front 2?
Quoted from jfh:I need to do this too. Did you do all 4 or just the front 2?
At this point just the front two corners, I heard the rear corners have never been an issue.. if anyone has heard differently let me know as I will upgrade those brackets as well.
Quoted from Concretehardt:At this point just the front two corners, I heard the rear corners have never been an issue.. if anyone has heard differently let me know as I will upgrade those brackets as well.
Never heard of the back splitting, but seems logical to change all 4.
PBL for the main brackets and Home Depot carries the smaller brackets and the screws. I predrilled the holes to the appropriate undersize and then used some wood glue on the threads.
Quoted from Concretehardt:PBL for the main brackets and Home Depot carries the smaller brackets and the screws. I predrilled the holes to the appropriate undersize and then used some wood glue on the threads.
Im going to pass on the smaller ones.....not sure they are needed (?)
Quoted from MK6PIN:Im going to pass on the smaller ones.....not sure they are needed (?)
They may be overkill, I saw people had been using them in another thread on the subject. If I do the rear corners I will just do the main brackets as the cab is stronger in the back to start with.
Did you use the Williams ones or the DE/Stern ones? They sell both kinds, the DE/SEGA/Stern ones are a little shorter than the Williams.
The splitting seems to start at the top, not so reinforcement near the top is probably a good idea.
Quoted from Robertstone0407:Can anyone tell me where to get that cool speaker light kit with the bat symbold?
Sold by yelobird/The Mod Couple.
Quoted from Concretehardt:I really like the looks of this kit!
Probably my all time favourite mod, pictures don't do it justice, just pops and looks awesome on the game
Quoted from jfh:If anyone is interested in a speaker mod kit, I have an unused/uninstalled one I have decided not to use on my LE that I will sell at a discount. Also a new yelobird phone mod. PM if interested.
Pm sent
I like this game.
Fun and play again factor.
This new code 0.84 is a great improvement in my opinion. I hope Lyman will keep his momentum going!
I know a couple of people here were having issues with the crane sensitivity. In my case, the crane was not registering hits on the 3 left-most positions. Turns out there was a split cable to the metal cage housing the pendulum (pictured below). The crane movement and the tight cable-ties were pinching it. Had to split it, strip it and twist it back together. Crane now registers every hit!
Quoted from melumga:I know a couple of people here were having issues with the crane sensitivity. In my case, the crane was not registering hits on the 3 left-most positions. Turns out there was a split cable to the metal cage housing the pendulum (pictured below). The crane movement and the tight cable-ties were pinching it. Had to split it, strip it and twist it back together. Crane now registers every hit!
Good detective work!
Quoted from jfh:Board fix kits must be done. Just got a shipping notification from Stern.
I've never received a shipping notification from Stern for anything that they owed me.
Quoted from thundergod76:I've never received a shipping notification from Stern for anything that they owed me.
Just got my notification as well....did hot glue for the vibration, however. Will definitely insert the cap.
Changing all my ethernet cables to Ortronics CAT6 certified at the same time. Doesn't cure a potential jack problem, but cabling will now be a non issue......
Ok. I’ve been slacking on keeping up here. What’s going on with sterns most expensive pin ever that I need to be worried about? Do I need to contact them for a potential fix?
Thanks.
Quoted from Pinfactory2000:Ok. I’ve been slacking on keeping up here. What’s going on with sterns most expensive pin ever that I need to be worried about? Do I need to contact them for a potential fix?
Thanks.
