HOLY NEW BATCODE!
big file 3.5gb
V0.65 - January 11, 2017
- Added/implemented new Joker standup target switch.
- Added Penguin crane lamp to the background lamp effect for the
penguin mode.
- Changed the priority of the background lamp effect for the fire button
so certain effects (HSTD initials, etc.) will be displayed.
- Fixed Catwoman speech; changed the Joker explosion.
- Added video/effects for major villains.
- Fixed issues with the major villain modes (one player's work
affecting another's).
- Increased replay and high score defaults.
- Fixed a bug in the Penguin mode that was causing state to be carried
over from player to player.
- Added sounds and speech.
- Fixed initialization of major villain advance.
- Added settings so it is not so difficult to restart the major villain
modes after failing to answer the Batphone.
- Disabled some background lamp effects for the turntable when the
turntable is in a different position and the shots cannot be reached.
- Disabled the Batmobile spinner switches so they do not register unless
the Batmobile spinner is facing the player.
- Improved ball handling for the turntable lock.
- Smoothed player transition animations.
- Fixed a bug where the player 4 score is highlighted at start of a new
4 player game after completion of a prior 4 player game.
- Tweaked position of 2 player scores to avoid line of background color
showing through at bottom.
- Added frame label to one player layout.
- Fixed an issue where the text bubble for the Batphone hurry-up award
was staying on the screen forever (or at least until the next batphone
hurry-up award).
- Fixed some issues with holding the ball in the kickout for super
jackpot.
- Lowered the scoring for the Batmobile spinner.
- Added villains captured display effects.
- Lane change no longer allowed for skill shot.
- Added turntable lock post test.
- Added settings for number of shots needed to light the super jackpot
for the major villains.
- Added grace period lamps for the Joker mode. Fixed an issue where a
Joker primary shot was not resetting the shot move timer, so, depending
on when the move shot was made, the next move would happen too quickly.
- Put background display effects in for minor villains and multiball.
- Added support for additional score frame backgrounds.
- Added ability to set text color in text bubbles.
- Added custom text bubble colors for each villain mode.
- Added villain vision effects for Batphone hurry-up.
- Added lamp effect for the Batcave targets.
- Updated and refined minor villain select.
- Added Batmobile spinner lamp effect.
- Fixed the gadget button lamp background to only blink when a gadget can
be applied.
- Added some speech to skill shot.
- Added light shows for major villains.
- Mystery lit when the bottom lanes are completed.
- Fixed issues with turntable awards during the major villain modes (some
were not scoring).
- The match effect was not quieting the music and sound. This has been
corrected.
- Start button press w/ no credits effects (sounds) now allowed after
power-up.
- Reworked Batphone hurry-up scoring.
- Reworked the infrastructure for the villain vision background display
effects.
- Cleaned up Batphone hurry-up so timers will be held.
- Reorganized the Batphone hurry-up start to take less time so it doesn't
tie up the display for such a long time at end of ball or when mystery
and/or minor villain select is trying to run.
- Removed extra gadget button dispatch that was causing double gadgets
to be applied.
- Fixed extra ball so that it lights correctly.
- Playfield multiplier from atomic pile has been changed to only be
awarded if the atomic pile is lit.
- Adjusted background lamp effect priorities so the background lamp
effect for the combos runs on top of the modes.
- Combo shot was not being awarded from the Penguin VUK. This has been
corrected.
- Updated score frame for playfield multiplier status.
- Added adjustment check for major villain mode super jackpot award using
the gadget button (default=NO).
V0.57 - December 15, 2016
- Initial version.
