New! Dark mode!
(Topic ID: 193988)
Batman 66 - lock problem, no multiball
By meeotch
  • 13 posts
  • 10 Pinsiders participating
  • Latest reply 9 months ago by Jabar999
#1 3 years ago
I've got a Batman 66 here that refuses to start multiball. With locks lit, shots into the lock will correctly register the first two. The third ball goes in, and rather than awarding it, the game completely loses track of the ball and goes into wait-and-hunt mode, periodically spinning the turntable and cycling the coils. It never starts multiball, though with three balls locked, you can often start it yourself by flicking them with your finger.
The three lock switches in the turntable are working - both with fingers and with balls. (Hmm - I guess that could have been phrased better.) As far as I can tell, the problem is that when all three balls are in the lock, and the lock post is up, they're packed so tightly that the ball furthest from the post (lock 1) actually lifts up enough to deactivate its switch. There seems to be no way to adjust the length of the lock lane. Either this, or a software error.
Before I go bending brand-new switches around to try and get it working, has anyone else experienced / solved this behavior? I couldn't find anything on it in the forums or the Stern website, but it feels like the kind of thing that might be a known issue - hence this post.
9 months later
#2 2 years ago
I had the same problem and e-mailed Mitch (OP). Here's what I report:
Ok, I'm not sure I have resolved this yet but it seems to be better. I have emailed Stern and they tell me it is switch related, however I'm not sure I agree. The "ball search" occurs regardless of 1 2 or 3 balls in the lock chamber. It can also happen on draining the ball as well (when there are locked balls in the chamber). I believe there might be a set of unique circumstances which lead to this happening, and perhaps it is code related. I have also tested the switches multiple times and find them to be working OK. Since I put the new code 0.90 on the game it seems to be much better, however very occasionally it will still fault. I can live with it at this stage, and now the game is on a commercial location I'm less aware of when or how often it is happening. I shall monitor, and report back.
5 months later
#3 2 years ago
I just purchased a premium and have the latest code and am still experiencing the same issue as reported by simonzzz. Any suggestions on a fix?
#4 2 years ago
Are you sure it's not a faulty third switch? You tested it in the test menu I trust...
#5 2 years ago
Quoted from jorant:
Yes, I tested it in the test menu and it works fine. I did notice last night that one of my Joker Targets was installed slightly below the playfield so that it was stuck closed. I am wondering if that switch being stuck closed plays any part in the machine losing track of the locked balls thinking that one is still in play or not. Once, I figure that target out, I will see if the lock problem continues.
#6 2 years ago
Quoted from murdock:
Those stuck targets are a known issue with this game. There are many posts and solutions to correct the issue. It does need to be addressed though. Good luck!
7 months later
#7 1 year ago
I'm having the same issue on my brand new machine
I reached out to stern support and they provided the following suggestion:
"These switches are known as “micro switches.” They have a small, pill shaped button that is actuated by a metal reed. This reed acts as a lever to make pressing the pill shaped button easier. The metal reed can be bent slightly to increase or decrease the leverage. In your case, the reed should be bent somewhere near the center of the reed so that more of the reed is exposed to the ball. This will give the ball more leverage to actuate the switch."
But I'm really not clear on what's being suggested or if I have to dissemble the rotisserie to do so. I tried futzing a little bit with it without success.
#8 1 year ago
It's odd that it's a known problem and a game that is getting code updates. There's no reason (afaik) that the third ball needs to sit in the lock mech to start multiball, just have it start on that third right orbit. For ball lock one and two, won't a weak right orbit shot credit the lock even if it doesn't land in the physical lock?
#9 1 year ago
Quoted from misterschu:
That is a slick solution... Lyman please do this
#10 1 year ago
Yea software fix would be nice...it is a huge bummer not being able to do multi-ball. Last night I even took switch the 3rd lock switch out reseated the metal leaf and it still didn't work! Support is sending me a new roller switch so I guess i'll try that.
#11 1 year ago
It's an especially troublesome issue because the switches are hard to reach for switch test and even harder to adjust.
#12 1 year ago
I am having the same issue on our new machine....it will not release the second ball or the third when suppose to for multiball. It then does ball searches over and over until it eventually rotates enough to drop them. Anyone know how to fix this? I can't tell if it is a switch issue because in testing they work fine. Any ideas out there?
6 months later
#13 9 months ago
Yes I can’t reach switches to adjust. Do I need to remove plastic. Getting it from under playfield is an even bigger headache
Docquest Pinball Mods
$ 16.00
Pin Monk
