(Topic ID: 280521)
Bare wood EM playfield repaint
By dr_nybble
11 months ago
  • 55 posts
  • 29 Pinsiders participating
  • Latest reply 3 months ago by Limorange
  • Topic is favorited by 39 Pinsiders
There are 55 posts in this topic. You are on page 2 of 2.
#51 5 months ago
Great results, looks awesome! Anything you did differently or advice to pass on? What paint did you use.
#52 5 months ago
Quoted from dr_nybble:
If you're asking me.
1. Scan and get that black ink outline. Helps keep everything in line.
2. In my case, the ball players were a little too detailed for my cutter. Even had a friend try on his machine and some of the super fine detail got lost. I think next time, I will create water slide decals of these super fine details and apply over the general color, in the case of the ball players, the decal would be on top of the white for the uniforms.
3. I used Golden high flow paints. I used the color matcher app Golden has on their site as I was trying to keep the machine looking old as that is what the customer wanted. I think I used 5 colors just to make the dirty white.
4. make sure to try out your masking film before you plunge in. I bought several kinds before I settled on what I used.
5. As stated by dr_nybble Spray light coats and build to your final color. Once I had the color I wanted and before I went to the next color I heat set the paint with a hair dryer. This helps prevent the masking from pulling up set paint when you do another color. Remember that once you heat set it, you can't wipe it off with water. It has to be sanded or scrapped off. I had to do that in a few areas were I had over sprayed.
Hope that helps.
Mike
#53 5 months ago
Nice outcome. A lot of work plus you need to learn vector software and the cutting software, airbrush techniques, masking, Appling stencils without bubbles. It's a huge project and most don't realize the amount of time and work to produce those results. You mastered it.
2 months later
#54 3 months ago
Thoroughly impressed with your hard work and your vast skill set!
#55 3 months ago
Absolutely magnificent! Thanks for taking the time to write it up with great detail, it takes out a lot of the guess work for the process.
