Hi all.
I present to you my latest mods for the LOTR.
work that I started a little over a year ago.
I created 3 mods and I started with what seemed to me the easiest, the ring fire that some people know to have bought it on my site or at Mezels mods.
I then started the "Barad Dur" project at the start, I wanted to integrate a half sphere with a mini screen between the two points of the tower, I finally gave up because although the effect was terrible, the installation was pretty complex.
so I decided to put an oval lens in the panel decor which holds the sticker of the eye of sauron flasher.
it took several tests for the alignment to give the impression that the eye is between the points of the tower.
so I cut some panels and modified the drawings of the original panel, because the eye of the flasher was badly centered.
once the concerns of centering settled, I added an interactivity so that with each action on the tower acts on the eye and especially so that during the destruction of the ring there is a longer animation which looks a little in the film, it was a bit complicated because the image file is very heavy but for an excellent definition.
in the control cards that I use, there is only little storage space
here is a photo of the panel ready to be installed, it only takes 5 minutes
