In a recent for sale thread of a Banzai Run game, one our pinsiders (Mike) noted that the trim that goes at the top of the lower playfield glass was missing.
Mine is also missing off of my Banzai Run. As I was about 8 years too late to get any leftover pieces that Mike had, I opted to buy the same stuff he did from McMaster Carr and give it a try.
I'm not going to lie, this stuff is a bit of a pain to get onto the glass as it has an internal metal channel that you need to spread apart to get the piece on. Once it's on, then you need to pinch it onto the glass so that it stays in place and so it clears the upper playfield flasher dome as this is slightly thicker than the original plastic piece that was there. I was able to do this by hand and I believe Mike used pliers to do it.
When I measured the distance between the rails, I came up with about 20.5 inches. I decided to cut the pieces into approximately 20 inch pieces. This way, when you put it on your glass, you'll have about a 1/4 inch on either side to allow the glass to slide without contacting the side rails.
One other thing I noted is that because you now have this thicker rubber piece on, your playfield glass won't slide in as far as it used to but will still go far enough for you to put your lockdown bar on.
I've included a couple of pictures of the piece in place and the extras that I have (5 in total). If you want one of these, let me know. I was thinking $10 shipped per piece.
Dave
