(Topic ID: 264621)
Bank Shot score motor won't stop
By thevcrman
1 year ago
  • 16 posts
  • 8 Pinsiders participating
  • Latest reply 1 year ago by thevcrman
#1 1 year ago
I have cleaned all contacts. The counters reset. The bar resets. AX relay never releases. Fixed a dozen bad connections to get to this point. Please help before I have fire in the backyard with it!
Thanks,
Paul
#2 1 year ago
Please ask a mod to move your thread to the electro-mechanical technical subforum. You've posted your issue in the early electronics game subforum - totally different beasts.
https://pinside.com/pinball/forum/forum/tech-em
#3 1 year ago
OOPs, how do I do that?
#4 1 year ago
ForceFlow Daditude TigerLaw , can one of you move this over to the EM tech area? Thanks.
#6 1 year ago
If the score motor is running and you manually trip the AX relay with your fingers, does the motor stop and kick out A ball?
#8 1 year ago
Quoted from thevcrman:
Do you have a schematic for it? Here's part of the Buccanneer schematic that may be the same:
You'll need to sort out why your AX relay isn't resetting. It could be that one of the 5 switches shown isn't closing or that the relay is magnetized or mechanically bound somehow. Start by measuring the resistance across the switches. Each one should measure an ohm or less when closed. If they all check out use a bulb tester (described elsewhere in the forum) to see if the AX Reset relay is getting a pulse at the end of reset.
/Mark
#9 1 year ago
Thanks so much for the help. I do have the schematic, wish I had a startup sequence. I will try that as soon as I get / make a bulb tester.
Paul
#10 1 year ago
Made a bulb tester, thanks for the information. I think my problem lies in the ball counter. I think the switches on the inside are missing spacers. Where can I get these switches.
Paul
#11 1 year ago
You can make them from parts
http://www.pbresource.com/pfswitch.htm#common
#12 1 year ago
Great, thanks
Paul
#13 1 year ago
I’d post a picture here and then you’d get some feedback on whether the unit has been hacked up or not. Anything is possible, but I’d hate to see you buy a bunch of parts and do a bunch of work and still be stuck.
Regarding the startup sequence, I’d search pinside for the game and look at all the tagged threads to see if there’s one on walking through the startup to get some info. There’s almost always one that someone has had to go through before you . I continue to be amazed and pleased by all the archived info here that has helped me tremendously. It saves me from having to post new threads about my troubles.
Good luck,
Dave
#14 1 year ago
Here's a generic Gottlieb start-up sequence that may help:
http://www.pinballaustralia.com/startupG.htm
#15 1 year ago
Thank you to all for the great help. I actually got my Captain Fantastic working again because of it. Fixed the switch, still no connectivity through ball counter.
#16 1 year ago
Does anyone have a picture of the ball count mechanism, I think the one I have was rebuilt wrong.
Thanks,
Paul
