New! Dark mode!
(Topic ID: 120734)
Ballys / Switch used for Free play
By Raff
5 years ago
  • 27 posts
  • 9 Pinsiders participating
  • Latest reply 5 years ago by Raff
There have been 9 images uploaded to this topic. (View topic image gallery).
#1 5 years ago
if i wanted to set my ballys star trek to free play with a switch / whats the best switch to use for it and a link to where i can buy one would be good
#2 5 years ago
it just doesnt work that way..
your options are a switch across the coin switch, an extra leaf on the start button to add a credit each time, an alltek board, setting replay to 10k so you always get it, setting a coin slot to 15 credits per coin and using it as a money box.. or . i probably missed one . you get the idea. there is no 'free play' setting on the standard mpu.
#3 5 years ago
https://pinside.com/pinball/forum/topic/setting-a-bally-to-free-play
this is a nice clean way of doing it, it's from pin logic but the site seems to be down right now.
#4 5 years ago
this is what i did to one of my machine (red push button). it's connected to coin switch.
#5 5 years ago
Quoted from beatmaster:
cant type ...blinded by shiny door
#6 5 years ago
Unfortunately, Tom Callahan of Pin-logic closed business. I should have bought up all his coin door switches.
#7 5 years ago
Quoted from wiredoug:
lollll, gotta wear sunglasses when playing this machine.
#8 5 years ago
Quoted from SealClubber:
hmmmmm, not sure but i think i saw somewhere something similar... gonna have to look.
#9 5 years ago
sorry i should try explaining it a little bit better i just need to know what this switch is called and where to buy it from , the two wires are connected to the switch on the outside and the coin switch press the button and the games pop up
#10 5 years ago
I've got a Future Spa and an Embryon, both of which have one of the coin switches mounted in such a way that the reject button activates them.
#12 5 years ago
i knew something similar could work, like this.
http://www.pinballlife.com/index.php?p=product&id=2801
#13 5 years ago
the red switch looks good mounted on the inside ,so that switch is it just a standard on and off, by the way your door looks like it just came off the production line
#14 5 years ago
you want single pole single throw SPST push on momentary N/O ( normally open).
jaycar CAT.NO: SP0700 is an example but there will be other smaller ones
#15 5 years ago
any arcade fire button will work (thats what you have there, similar).
you could use a flipper button with a leaf switch behind.
#16 5 years ago
going to jay car tomorrow I am sure i will find a switch there , should i be adding a diode to it
#17 5 years ago
Quoted from Raff:
nope.
#18 5 years ago
how about a free play rom? you may have to change jumpers though , epending onwha you have as a u6 in the game now.
#19 5 years ago
It actually looks pretty darn close to a Gottlieb system 3 trough switch, but with a different wire on the switch.
[edit]: Actually, with the right parts, this actually might be something I could re-make. Plus, I have examples of Bally (sort-of), Stern, and Gottlieb coin doors, so I might be able to adapt something to fit all of them. I'll have to think about this a bit more this evening.
#20 5 years ago
On a Bally, we move the coin switch up high enough that the coin reject plate hits it with the coin mech removed. That way there is no exposed switch and the door looks stock. Just push the coin return for a credit.
#21 5 years ago
Does it matter where you connect the wires
To the switch lugs
#22 5 years ago
You can just wire in two additional wires to the start switch and connect them to the center (unused?) coin switch. Toss a diode in the line and you shouldn't have a problem. I rig all my Bally's to run free play off the start switch either through this method or through a second leaf switch behind the Existing start switch. Adds a credit and starts a game at the same time. I can upload a picture of what I'm talking about later tonight, but it's a very easy wire-up.
#23 5 years ago
Quoted from Collin:
Wait, doesn't Embryon have a free play setting? Been a while since I had one, but I swear there's a dip switch on that game for it.
#24 5 years ago
photo 3.JPGphoto 2.JPGphoto 1.JPG works good
#26 5 years ago
Here's a photo just in case. Essentially, just connect your coin wires to the start switch, inserting a diode to the same tie in as the existing diode. No need for a second switch where you'd have to open the door, and it credits and starts a game at the same time. I put a connector in their too for quick disconnect to coin play.
#27 5 years ago
I will use your way goonie with a diode and just connect the coin wires to the start button on my royal flush machine
$ 149.95
Allteksystems
$ 49.99
PinballElectronics.com
Third Coast Pinball
$ 103.00
