(Topic ID: 178455)
Bally zipper-flippers "chatter" when trying to close
By JReedie
7 years ago
  • 6 posts
  • 6 Pinsiders participating
  • Latest reply 35 days ago by Garrett
#1 7 years ago
Hello everyone does anybody here have any knowledge on Bally's quirky "zipper flippers"? I'm currently restoring a 4 Queens and whenever the flippers try to close they chatter together and make a horrible sound and then after about 2 seconds of chattering they reopen. Yet brilliantly whenever I lift up the playfield to try and catch the problem and trigger the switch that closes the flippers they work perfectly. I do have a video of it happening but don't know how to share that on this forum.
- James
#2 7 years ago
Quoted from JReedie:
no idea of the setup of that game but I've found that the old works-with-playfield-up issue is usually a gravity thing making a too close gapped switch activate(especially on double leaf 2 stage type switches). The symptoms you describe would also make me think it's a switch gap issue causing them to fire like that.
#3 7 years ago
- James
If it's fixing itself when the playfield is up, that just means a switch is out of adjustment (which it sounds like anyways) and the extra gravity of it being at a different rotation is bridging the gap. Could be dirty as well, and the stronger push of the gravity is creating a better connection.
#4 7 years ago
gravity may affect the hold solenoid armature as well , is the spring on the back of there perhaps missing ?
http://www.planetarypinball.com/reference/partsmanuals/BLY_Parts_1973/index.html#/172/
7 years later
#5 35 days ago
@J Reedie- I’m having similar issue on my Four Million BC. Did you figure out this problem. Thanks
#6 35 days ago
Quoted from Jeepntucson:
Check out this thread for more info on the zippers.
https://pinside.com/pinball/forum/topic/bally-zipper-flipper-details-amp-parts
This page was printed from https://pinside.com/pinball/forum/topic/bally-zipper-flippers-chatter-when-trying-to-close and we tried optimising it for printing. Some page elements may have been deliberately hidden.
