James -
Test the high voltage at the connector pin on both ends. It should read about 175VDC. If you're missing the high voltage at the display only, but have it at the MPU end, then you have a bad wire/pin. If you don't have the high voltage at each pin (At the MPU and at the display) then you have an issue at the MPU board. You should be able to access the side of the pin with the connectors on.
Its possible that you have a corrosion damaged pin at the MPU connector that feeds the voltage to the display. Repinning that entire connector is likely the best thing to do.
As an aside, to verify a corroded pin, insert a paper clip into the pin a few times, then connect the connector and see if the display comes back. If it does, then you have a corroded pin and should replace all the pins on that connector. This may not always work, but its worth a try.
It should go without saying, but do this with power off. Also, do not connect and disconnect the connectors with power on. You can really mess something up.
