i hope some pro on here could maybe come to my rescue, i been trying to figure out this issue for like 2 weeks now and i just aint making any headway with it.
okay here is the problem. when u start xenon, it says welcome to xenon ... and then this sound effect. well on my game, there is just some random noise when that sound effect should happen, the welcome to xenon is there. if u press the inlanes and outlanes, it just sounds like whitenoise. but if i trip the drop targets they make sounds, the music works the voices works etc. also those sling targets at the back just make some white noise. the targets on the side near the ball lock, those sounds work.
here is what i have done sofar.
replaced the pia on the soundboard, replaced the ram on the sound board. replaced the cpu chip on the soundboard. i even converted the soundboard to a 6802 so the ram is cut out of the mix... i checked the traces for everything on the board, checked the wiring going from the soundboard to the cpu board.
redid the connectors on the boards and on the wires... checked the wiring from the board to the cpu board to make sure its going where it should from the schematics.
tonight i even put another cpu board in to rule that out, still did not change a thing. i changed the u11 pia on the cpu board and the ram on the cpu board. still the same issue.
so my thinking its either a soundboard issue, but i mean what else could be wrong on the board? i basically replaced most of the chips...
ribbon cable issue? i dont know how that ribbon cable works if it plays a big part in the sound or just the voices? cause well the voices all work so i dont know.
