Hey all,
Need some guidance. Got this machine from my friend. Has run great for years despite nothing been done to it. Lost the sound one day and decided to invest some parts in it. Recapped the SDB and sound board, and replaced the 3.6VDC lithium battery on the MPU board with a 4 AA battery holder with a blocking diode in the 4th position to be remotely mounted. No alkaline damage at all. Lithium battery looks like a retrofit from years prior.
Since doing this, the MPU locks on, solid LED, immediately turn it off and on, then I get two flashes and thats it. Hitting reset button on MPU does nothing.
Here is the kicker, I reinstall the 3.6V lithium battery after waiting 5 minutes or so for the residual charge to dissipate, and whatdayaknow...8 flashes everything boots up great, sound is back, all is good.
So whats up with this? I thought 4.5VDC was okay for the onboard memory? Blocking diode is for non chargable batteries.
My guess is that there is something wrong with the MPU reset circuit? Bad non volatile memory? Or am I way off?
I have rebuilt my entire OEM board set for my Embryon so I'm no stranger to this work or dealing with glitches. This one has me a bit stumped though. Can really use some direction.
Pinwiz
