Hi groobo
I would first concentrate on "power-on and immediately the Score Motor starts turning".
Lets look at the schema in ipdb.org: http://www.ipdb.org/machine.cgi?id=2803 -> schema.
The symbol for the Score Motor is at 10-E / 10-F. A bit below there is a "fork-off to the left". There are switches drawn "on the left" - and there are switches drawn "on the right".
When one or more switch is "faulty-closed": The Score Motor will start to run.
First step: Look for Reset Relay, Coin Relay, 2nd Coin Chute Relay, 3rd Coin Chute Relay. If You power-on: Does one of these Relays start to pull (this would be the fault) ?
Second step: in the schema (near the "Switch on 3rd Coin Chute Relay") at schema-9-C there is the "Score-Motor-Switch-1-F". It is a "Make and Brake Switch", drawn "closed on the right hand side". It is the "Self Hold Switch on the Score Motor", needed for "once the Score-Motor gets an impulse: "Make a turn" -> this switch makes the Score Motor to make "180 degree turn, complete"".
The middle blade of this switch has a wire "White" soldered-on. The Outside blades have soldered-on: Wire-Black-White /// Wire-Red-Yellow. If the blades are bent and there is always (faulty) contact "Red-Yellow <-> White": The fault.
Third step: Have a look at the relays "on the righthand-side": Outhole Relay, Right Lane Relay, Hole Relay, Center Target Relay, 5000 Relay, 500 Relay, Bonus Score Relay: Is one of these Relays "faulty-pulling" at power-on ?
If You do not find the fault: The next step would be - "considering the Relays are good (not pulling) - BUT a Switch on one of these Relays is bent and makes "faulty contact when relay is not pulling"": You must have another look at all these relays looking for a "Switch faulty-(always)-closed".
Greetings Rolf
