(Topic ID: 234170)
Bally Wizard double bonus not working
By spetrucelli
2 years ago
  • 6 posts
  • 2 Pinsiders participating
  • Latest reply 2 years ago by newovad
    #1 2 years ago
    I have a Bally Wizard machine. The double bonus feature is not working. The flag flips and the rollover lights up. However, when the flag flips back the double bonus light does not activate and the double bonus does not work. Any suggestions on how to trouble shoot and fix this?
    #2 2 years ago
    Check the Double Bonus relay. It is the second to last one on the left in the bottom of the cabinet. This is a hold relay, so it clicks in place when activated until the end of the ball. I would suggest you activate it manually to see if it works. That would determine the next step
    #3 2 years ago
    It definitely works. Now what?
    #4 2 years ago
    Check the Right Lane Relay. It is under the cabinet, first one on the left (I believe). Check the wiring/contacts for the third set of switches on the relay.
    #5 2 years ago
    All wires are connected. No issues from what I can see.
    #6 2 years ago
    Did you check the contacts on the switch stack to ensure they connect when the relay is tripped? Are the contacts clean? If they are out of alignment, they can't trigger the Double Bonus relay. Same if they are overly dirty/corroded.
