(Topic ID: 283336)
Bally Wizard bonus countdown issues
By Sea_Wolf
  • 18 posts
  • 7 Pinsiders participating
  • Latest reply 3 years ago by I_P_D_B
#1 3 years ago
One of the many issues with my new dirty project pin is with the Collect Bonus countdown. It advances the bonus correctly up to 19,000 but when the ball drains and the countdown begins, the bonus unit spider moves one rivet at a time or two at a time when the Double Bonus is lit like it should for two or three spots but then spins and resets back to the home position so it only rewards you 2 or 3 thousand on the countdown even if you earned 14,000 for example.
I’ll try to post a video of the Bonus Unit in action soon but just wondering what might be causing this. I’ll have time to unscrew the bonus unit from the bottom board this afternoon to further inspect it. Thanks for any help.
#2 3 years ago
Quoted from Sea_Wolf:
It seems that the Bonus relay isn't holding.
#3 3 years ago
Quoted from currieddog:
That’s exactly what seems like is happening. Thanks for this and I’m going to be posting a video here in about an hour.
#4 3 years ago
Sorry not to show more info but the schematic on IPDB is a jpg and hard to get a good snippet.
#5 3 years ago
Here’s a pic and video of the BCU counting down from a 9000 point Collect Bonus.
It is a little more dramatic in this video. Sometimes it counts a few thousand before spinning back to the home position and is it really the correct home position? Maybe a Wizard owner post a picture of his in the correct position. Thanks.
69E543DC-539F-4641-AF76-BC7964DDA5B6 (resized).jpeg69E543DC-539F-4641-AF76-BC7964DDA5B6 (resized).jpeg
#6 3 years ago
Check the ratchet catch pawls for sticking on the BCU.
#7 3 years ago
Quoted from pinballdaveh:
Finally got better access to the inner part of the BCU. Thanks for making me look there. Look at the worn down teeth on this unit.
This game is a mess. I wanted a winter project and I surely have one. This is #3 on a list of 12 known issues on this machine and I’ve only solved 2 so far and this.
Wondering where to look for a replacement. Thanks again.
A6D257C2-B778-41AB-8D4F-6DDD26E2593E (resized).jpegA6D257C2-B778-41AB-8D4F-6DDD26E2593E (resized).jpegE7E96F01-4D62-442E-8BF6-D76FABF7F811 (resized).jpegE7E96F01-4D62-442E-8BF6-D76FABF7F811 (resized).jpeg
#8 3 years ago
Or am I going to have to wait till someone parts out a machine?
#9 3 years ago
Sorry I referred to this unit as a BCU in above posts. Obviously it’s the Bonus Unit and not the Ball Count Unit.
#10 3 years ago
Any way to take it apart and shift it over to fresh teeth or does it use the whole gear all the way around? If it just uses the same 15 teeth over and over you might be able to move it around.
If not, pinball resource....
#11 3 years ago
After some quick searching, it seems this is a common issue on Wizard and that gear is only used on Wizard. Based on this thread.
https://pinside.com/pinball/forum/topic/bally-stepper-gear
Maybe you could dremel some teeth back into that area??
#12 3 years ago
Put an ad in classifieds here. I've had very good luck getting some odd parts.
#13 3 years ago
Quoted from slochar:
That’s a great idea. Never would have thought of that but that sounds like it would work if I can’t find one.
#14 3 years ago
Quoted from RC_like_the_cola:
Yeah and this particular Wizard has been really neglected on top of that. I’ve got a dremel, just trying to figure out how to make that work.
Thanks for the suggestion.
#15 3 years ago
Thanks, I finally did post it and already got a hit but unfortunately, the offer was not quite the same gear. The stopper pins on mine are located directly opposite of each other.
Appreciate the help.
#16 3 years ago
If the gear fits and works stopper pins can be mounted wherever you want them.
#17 3 years ago
Quoted from phil-lee:
Thanks. I’m starting to now figure that out. I just bought a gear from a local guy and it will fit but I’ll need to cut the plastic pin off I guess because it doesn’t line up correctly.
Then drill a small hole where I need it and insert a small screw to act as a stopper? Is that how you’d handle it or is there something else you would use as a stopper pin?
2 months later
#18 3 years ago
It's now a PDF.
1,200 (OBO)
Murrells Inlet, SC
Pomona, CA
2,750
1,200 (OBO)
Shrewsbury, MA
$ 69.00
Pinball Pimp
Precision Pinball prod.
This page was printed from https://pinside.com/pinball/forum/topic/bally-wizard-bonus-countdown-issues- and we tried optimising it for printing. Some page elements may have been deliberately hidden.
