Mod question - too many items plugged to j116???
Has anyone had issues or have a suggestion about the gum ball dazzler mod being used on a TZ that also has a color dmd. My issue is that the color dmd hooks up to pin j116 with a z connector that joins the original harness to j116. No problems.
But the dazzler mod also goes to j116, so that’s 3 harnesses going to that pin. It worked fine for a few days but one day I turned on the machine and it factory reset and the flippers started firing. Then a fuse blew. I unhooked the dazzler from j116 and Machine is playing fine.
Any suggestions?
