I just installed replacement coin doors on my theater of magic and Attack from Mars. Previously the Coin door lights worked but now with the new doors they will not. Any suggestions?
Quoted from attitude05:I just installed replacement coin doors on my theater of magic and Attack from Mars. Previously the Coin door lights worked but now with the new doors they will not. Any suggestions?
Did you check to see if there there are bulbs installed in the new doors?
I'd grab a meter and check AC GI power to sockets - if none then to the coin door interface board.
Not knowing what door you put on, did it come with an appropriate harness to plug right in ?
If you had to wire it in, did you get the socket wires to the right spot on the coin door interface board ?
If all you worked on was up front, I'd concentrate on that area. Not likely you have a connector off in the head.
Quoted from attitude05:The doors have the connector.
Do they have the adapter plugged into the connector too ?
See the adapter circled in red - do you have that ?
If so grab a mater and try and figure where you lost power. Which would be strange on two doors.
cdoor (resized).jpgQuoted from attitude05:Would a ground issue cause that?
No. Coin door lights are AC. Hot to common.
Please take a meter, set to AC. See if you have power at the coin door light sockets - and leaving the coin door interface board. Connector J5 pins 1 & 2.
Did you check if your coin door harness has the adapter, or have you checked if your coin door harness has wiring from the light sockets to the coin door interface board. Connector J5 pins 1 and 2 ?
I suspect you are missing the adapter or wires, since you have a common problem on both doors/games.
Do you have any idea where to get the adapter?
I have this exact same problem and I am missing it. I did a quick search and I could not locate one.
Quoted from justdavid:Do you have any idea where to get the adapter?
Marco sells the Entropy coin door with it - https://www.marcospecialties.com/pinball-parts/09-61000-X
I don't know of anyone that sells just the adapter.
Quoted from justdavid:I have this exact same problem and I am missing it.
J5 on the coin door interface board has an IDC connector to it. I would run two wires from the coin door lights to pins 1 & 2 on J5 and using an IDC insertion tool stick the wires in J5 and be done with it.
Old pic. The coin doors used to need an adaptor 15 years ago.
The original doors to hit the market many years ago were overstock from Entropy when WMS closed their pinball devision. These overstock doors were originally meant for Pin2000 machines which used a different harness. We made an adaptor harness so that these doors would work on WPC and WPC-95 machines.
Once the overstock doors dried up we remanufactured the doors to work with WPC and WPC-95 machines, so the adaptor harness was no longer needed.
I see Marco's picture also shows the adaptor harness.
Buying a door from them will not include an adaptor harness either.
Again, an adaptor harness no longer needed.
I guess we should both update our pictures!
As for the lights not working I have no idea. The batch of doors we have in stock we have been selling for 1-1/2 years with no issues
Terry.
So for the original poster.
Please check power at the sockets - yes ? check if bulbs are good. No, then check power to the coin door interface board - Yes ? Then check power leaving board - yes- then follow the wiring for a break. If no power to the coin door interface board, then check if a connector on the power driver board is off, or hidden behind the board or in the wiring. Then check power leaving that board. If power is going out then follow along the wiring for a break to the coin door interface board.
This is AC, so set your meter to AC and check hot to common, not hot to ground.
Quoted from attitude05:There is power to the board but no power at the socket.
You've narrowed it down. Power leaving the board ? No, then board issue. Power leaving the board ? Yes, then follow the wires to the socket to see if you have wires going there from the board to the sockets, and if there is a break along the way.
This page was printed from https://pinside.com/pinball/forum/topic/bally-williams-coin-door-lights- and we tried optimising it for printing. Some page elements may have been deliberately hidden.
