(Topic ID: 234788)
Bally Vector restoration Help!
By Jordan_H
8 months ago
  • 33 posts
  • 7 Pinsiders participating
  • Latest reply 7 months ago by whizz
There have been 6 images uploaded to this topic. (View topic image gallery).
#1 8 months ago
Hi all, I’m a fairly green pinballer, and recently I bought my first pinball machine Bally’s Vector. I’ve been working on bulletproofing my non working Vector. I have all proper voltages on my rectifier board’s test points. BUT I have a weird 178mv DC on my sol. driver board at TP 1 and 3. My other TPs on the solenoid board are fine. I’ve replaced the high voltage components (high voltage repair kit) AND the 5v side has had everything replaced except the two large disc capacitors which my parts supplier forgot to ship in the 5v repair kit. Wondering if anyone knows where I should start looking in order to get my 5v DC? Thanks gang
#2 8 months ago
#3 8 months ago
Did you repin the wired connector and the male board connector at the top right of the solenoid driver board? Did you repin/replace any rectifier connectors yet?
Basically, part of bulletproofing the game would be to replace all male and female connectors.
#4 8 months ago
That 5V regulator looks like one of those junk fake units from China.
See these two posts:
https://pinside.com/pinball/forum/topic/meteor-resets-with-rottendog-solenoid-driver-board#post-4688080
https://pinside.com/pinball/forum/topic/meteor-resets-with-rottendog-solenoid-driver-board#post-4709895
Are you measuring 12V to 14V DC at TP5 on the solenoid driver board?
#5 8 months ago
Quoted from PinballManiac40:
I didn’t , but I flowed new solder, and they are the newer square pins and look to be in good shape
#6 8 months ago
Quoted from Quench:
I’m a little high at 17V DC at TP5
#7 8 months ago
Quoted from Jordan_H:
With no load being drawn through the 5V regulator, 17V is not unusual at TP5 (it's high because the big capacitor at C23 is holding charge at the peak of the supply rail).
What voltage are you measuring on the casing of the 5V regulator (the component in the middle of the big heatsink)? Make sure the screw holding the bottom of the regulator is making good contact with the trace on the back of the board. Check Resistors R49 and R50. If they're in spec and making good contact in circuit, then that 5V regulator is faulty.
#8 8 months ago
A couple of internal pictures of fake 5V regulators vs real regulators - notice the internal silicon die is larger on the real regulators and has more whisker connections.
https://pinside.com/pinball/forum/topic/lets-get-technical-ballystern-led-display-power-consumption#post-2983421
This one looks like yours:
https://pinside.com/pinball/forum/topic/6821-pias-from-china#post-4279650
This one although purchased from China looks more realistic
https://pinside.com/pinball/forum/topic/lets-get-technical-ballystern-led-display-power-consumption/page/3#post-3278633
A real LM323 5V regulator is rated to 3 amps. The fake ones are probably rated closer to 1 amp so they quickly fail in these systems from over-current.
#9 8 months ago
Quoted from Quench:
Thanks for the help guys, how do I measure the 5V at the regulator casing exactly? Where do I put my DMM leads?
#10 8 months ago
A functioning regulator in this circuit will have about 0.2V on the casing. The reason I asked for this measurement was more to check that you have good connectivity of the case to the circuit. 5V output of this regulator is actually one of its two rear pins, not the case.
So black multi-meter lead goes to ground (use the "GND" test point on the solenoid driver board), red meter lead you simply touch the regulators metal case.
#11 8 months ago
Quoted from Quench:
Do you have a good parts source? I used a reputable source but if it’s fake I’ll need a new one
#12 8 months ago
I’m actually getting 86mV DC on the casing of the regulator and 135mV DC at TPs 1/3 that I have jumpered together per online suggestion
#13 8 months ago
Looks like a Chinese dud. Most of the lm323’s from China don’t work. I always test them before soldering them in. Ground on the case and 12v on the input pin. If you don’t get 5v don’t install
#14 8 months ago
That was it! Was able to put my old 5V regulator back in and sure enough I got 5V! Thanks so much guys, now onto the next battle
#15 8 months ago
Great!
You might want to let this reputable source know what they're selling.
#16 8 months ago
quench looks like Pinside could use a "don't buy this fake part from xxx" thread.
#17 8 months ago
Alright guys some great progress today. When I got the machine I had a locked LED on the MPU board. After removing the battery and replacing with a lithium coin plus diode and doing a full corrosion clean/repair and replacing a 6810 chip I finally got the start up!! BUT other than a nice light show and a couple kick outs working I have no power to flippers, pop bumper or any sling shots. It does kick a ball out hitting the start button and it somewhat goes into a game, no sound (haven’t done much to ST board, and no flippers) where do I start? Thanks for any advice, I’m pretty green but progressing!
#18 8 months ago
where do I start?
Could be the J4 connector that plugs onto the MPU board. Sound and solenoids share "selection" signals.
Put the game in solenoid test mode, (press the little red switch inside the coin door 3 times).
Printed page 17 (electronic PDF page 22) has a solenoid identification table. While it runs through solenoid test mode the number on the player displays corresponds to the ID of the solenoid being activated.
If any of the solenoids are activating at the wrong number and/or not at all, please give us the full list so we can map out where the problem may be.
When solenoid #22 activates, you should hear the relay on the solenoid driver board click.
@quench looks like Pinside could use a "don't buy this fake part from xxx" thread.
Good idea. When I get a few moments will do it.
#19 8 months ago
Quoted from Quench:
So I found the little red button. It doesn’t do anything. Tried 3x tried holding it down
#20 8 months ago
Resoldering all the contacts on the boards is what i would start doing.
#21 8 months ago
What's the state of the MPU board in this? Any battery corrosion? Can you post some clear high resolution pics of it?
#22 8 months ago
I'd start by re-pinning all your connecters.
#23 8 months ago
Not exactly high resolution. But I sanded down/cleaned/descaled and got it back up and running
1BE09576-6B57-414C-956B-5C7601E449F6 (resized).jpeg26B2C9BF-C99B-429A-9EA2-96F1F39E7231 (resized).jpeg380A65AE-962D-4331-A5E1-ACA50D896D52 (resized).jpegDEFEBD83-BEFF-4803-9C03-5AE03913C152 (resized).jpeg
#24 8 months ago
who is your best parts supplier for pins and connectors? I’m sure it’ll be at least $100 in new pins and connectors
#25 8 months ago
Your connectors probably have corrosion in them. If you have a small Brass wire brush, disconnect J3 and J4 off the MPU board and clean those J3 and J4 pin headers with the wire brush. See if it makes any difference to your issues.
Great Plains is probably your best bet. Your game has "IDC" style connectors, you'll need to replace them (including the housings) with the 0.1" ones linked below. Connectors are cheap but you'll need a crimper which will set you back between $20 - $30. I'll let others chime in on good crimper options.
https://www.greatplainselectronics.com/categories.asp?cat=70
Don't forget to get the plastic keys to insert in the new connector housings where necessary so the connectors can't be incorrectly installed.
#26 8 months ago
Thank you so much Quench, so can I use the .1” Molex for everything?
#27 8 months ago
MPU board is all 0.1" connectors.
Lamp Driver Board is all 0.1"
Solenoid Driver board uses 0.1" and 0.156"
Auxilliary Lamp Driver Board uses 0.156"
Displays use 0.156"
Sound board uses 0.156"
You'll notice the difference in size between 0.100" and 0.156" when you look at them. The size refers to the spacing between the pins.
#28 8 months ago
Thank you! Just ordered a bunch of pins and connectors, gonna get to work
#29 8 months ago
Quoted from Quench:
okay so major progress! So i took the MPU board and cleaned the header pins with some sand paper, while the machine was down i also finished replacing all of my ST board kit capacitors. After putting the board back in the PAC voice guy started talking and i opened the coin door and of course found the correct red test button. (i was using the vector speed reset button earlier).
So i ran the test mode and it seems all of the solenoids are energizing when they should and the relay driver board clicks at Solenoid 22. None of the flippers do anything.
#30 8 months ago
Run the solenoid test again and hold both flipper buttons in. When it gets to solenoid #22, do the flippers quickly flip?
#31 8 months ago
Got it up and running thanks guys! Still gonna repin everything
1 month later
#32 7 months ago
Putting in new pins and connectors, Anyone know where I can find some .1” 28 pin ramp connectors? GPE is out of stock thanks!
#33 7 months ago
I have bought some from huskerfan on Ebay before.
$ 14.50
PinballElectronics.com
$ 16.00
Yorktown Parts and Equip
$ 149.95
Allteksystems
$ 7.65
Cabinet Parts
Third Coast Pinball
€ 3.95
Multigame
Third Coast Pinball
