While looking at the Yellow Bonus Reset Solenoid circuit (see below) trying to figure out what is making this come on before it should, I was able to account for the the two Score Motor switches. They were N.O.open and the Score Motor runs for most every thing you do so I knew it had to be able to run without the Yellow Bonus Reset Solenoid energizing.
This left the Reset Relays and Yellow/Green Bonus Relays. The only thing resetting was the bonus not the whole machine so that was out.
My focus went to the Yellow/Green Bonus Relays (see below). The Yellow Bonus Zero Relay contact had to be energized that was a given because as the bonus accumulated on the Yellow Bonus Unit the Yellow Bonus Unit Zero contact would close completing the circuit for the The Yellow Bonus Zero Relay.
Three left.
1 Yellow Bonus Relay, to me this was a no only because I went over those contacts and I never saw the relay hang up. so fore the moment I would move on.
2 Yellow Hole relay. If this was closed for some reason the yellow hole eject would be going off.
3 Left or Right Out Roll Over switch. They are so flush to the underside of the play field its difficult to see which state there in. I checked the right side first and checked for continuity. Sure enough there was a clear ring from my MM.
Thank you all for your help. This problem presented itself in a way that I couldn't get my head around. Your ideas and questions pulled me back into frame so I could finally see through the forest.
The Final Problem 1 (resized).jpglast problem right out roll over (resized).jpg
