Bally Triac Questions
By Hop-Pac
1 year ago
Stats
  • 23 posts
  • 8 Pinsiders participating
  • Latest reply 5 months ago by BigAl56
Find
Search this topic for posts matching certain words or written by a specific Pinsider. Or both!
There have been 6 images uploaded to this topic. (View topic image gallery).
#1 1 year ago
Does anybody know much about Triacs?
From what I can read they control GI and make them flash, are prone to fail, are no longer made, and are "easily" bypassed.
My questions are...
Does a Triac work with an Aux. Driver board? Does it require both?
Is there anything that can be used to replace a bad one?
What happens when a Triac goes bad...Do all GI lamps stay off?
And how are Triacs bypassed?
#2 1 year ago
In simplest terms, because the GI is AC (sinusoidal, current flows in two directions) a Triac is used. A regular transistor or SCR is basically constructed with diodes, so it can be used as a simple DC switch. A triac is preferred in AC circuits because it allows current to flow in both directions. The triac is just a solid state switch substituting what can be done with a mechanical relay. I have noticed that in early solid state pinball, we tend to see relays used for GI switching in Williams and Gottlieb games, and triacs often used in Ballys.
A possible replacement: http://www.marcospecialties.com/pinball-parts/BT138-600E
Hi Everyone.
I have been advised the following will work so this may help anyone else with this issue.
"I would use Jaycar ZX-7149 which is actually a BT-137-600V-8A Triac because it has an isolated tab meaning you don't need to use any insulating washers to mount the part - much easier."
You need to get the pin outs of new and old triacs so you can solder the wires in correctly. You can also drill a hole in the metal plate and screw the new triac in as it is isolated.
Regards
Clive
#3 1 year ago
So the triac, being a switch, is turned on and off by the small square Aux Driver board? If the triac goes bad, does it stay off? No GI?
#4 1 year ago
I don't have a Pac, but looking at the schematics there is a page which shows a GI flash driver board, that is the small board that turns on and off the triac. The schematics show A9J2-5 with the description "To pin 3 GI flash driver board".
What I see is: Aux driver J2-5----> GI flash driver pin 3 ----> triac.
If the triac is dead, then the GI doesn't have any return so the lamps are stuck off.
#5 1 year ago
If you search Pinwiki for "triac" there are a few articles that appear to be about making a test fixture.
#6 1 year ago
Recommend you check the bulb first:
To make the GI lamps flash on and off, Bally used a Triac bolted to the power supply board in the cabinet. The triac is cycled by the GI lamp flasher board mounted under the playfield. This flasher board is similar to a solenoid expander board. The output of a lamp SCR driver is used to drive a MOC3011 opto coupler that drives the Triac. As with the solenoid expander board, a dummy 555 lamp is connected to the SCR output on the flasher board to insure there is enough current draw to drive the MOC3011. Most likely this 555 bulb is burned out, and causing your problem. Also check the flasher board for bad (cracked or cold) solder connections. Check all the cable connections to the triac too. Lastly you can replace the MOC3011 chip.
#7 1 year ago
Great info. Thanks. I think I have triac issues on both machines.
On Pac-Man, the GI stays on for the pac-maze.
And on Gold Ball the backglass lights are always out. The playfield lights work and blink as they should. There are 2 Triacs in Gold Ball. I'm guessing one for pf and one for bg.
#8 1 year ago
Ok, hope that info helps. I had Elektra, which had triacs for the backglass, playfield and mini-playfield. Good luck.
#9 1 year ago
Does anybody know how to bypass a triac so I can see if the lights turn on?
#10 1 year ago
Near the power supply (in the cabinet) there should be two similar connectors.
One going to the triac and the other going to the transformer/power supply.
Those two connectors should fit together.
One would have a green and white wire, the other should have a green, white and a black wire.
The green and white wires should line up turning the GI on.
In this image you can see the connector going to the triac in the hand.
The other connector you can see near the large resistor.
#11 1 year ago
I'm not sure how you conclude that "triacs are prone to fail"?
I have found them to be one of the most reliable and robust semiconductors ever made?
#12 1 year ago
Quoted from Inkochnito:
Cool. Thanks Inkochnito. Will try that
Quoted from Homepin:
Just did a search about Triacs, and see a lot of the same type of posts about Triacs not working. And I seem to be having trouble with both of my games. I just figured they were prone to fail. Maybe I jumped the gun on that? Are they reliable? I don't know
#13 1 year ago
Yes you can jump the center pin to the left pin facing the front of the triac to make it switch on, the 3rd pin is controlled by low ground voltage which will switch it on. In this pic shown you would jump A1 to A2 to turn on the GI string.
#14 1 year ago
Triacs are tough to burn out most likely you have a problem in the switching circuit (G)
-1
#15 1 year ago
Also the pins are commonly known as B(base A1)E(emitter A2)C(collector G) the transistor should have its value printed on the front of it. Tip 102, BTE 500E ect. What is the value?
#16 1 year ago
Quoted from Hop-Pac:
I think what you are most likely seeing is threads discussing GI failures that just happen to include a triac in the circuit. Almost always there is something else at fault
http://www.pinballrevolution.com/threads/do-gi-triacs-ever-fail.674/
#17 1 year ago
I took pictures of my boards in my machines. So looking them over, I found this. A broken wire in Gold Ball.
#18 1 year ago
So I checked it out. And a quick fix = Backglass Lights!!!
And they flash when the gold ball comes out. Turns out, it wasn't the triac! One fixed, now on to the other.
#19 1 year ago
Quoted from gmkalos:
Triacs are not transistors and so they do not have a "base, emitter or collector" and do not have pins marked EBC.
They work in an entirely different way to transistors.
Well done to the OP for finding the problem. As usual, it is best not to overthink the problems and start blaming things when really most issues are common connector or cabling problems.
#20 1 year ago
Correct. A triac has 3 pins: Anode 1, Anode 2 and Gate. Congrats to the OP for finding the problem. The poor triac always gets the blame, lol.
9 months later
#21 5 months ago
So Elektra has 3 triacs? I only could find 2 in the bottom cabinet. Old thread but hoping to piggy back on this as I am having the same problem. Weird part is I can jump the triacs to turn on Playfield gi.
#22 5 months ago
Quoted from FlipnFargo:
There are two triacs, located on the power module, and a solenoid expander board with a lamp under the playfield that switches between upper and lower playfield if I remember correctly.
Check out the video here which talks about the solenoid expander:
#23 5 months ago
The solenoid expander/flasher board is more likely to be the culprit than the triac. It requires a dummy lamp to activate and if you replaced all the lamps with LEDs the flasher board will not work. Of course if the wire going to the Triac is broken that is not going to help either.
€ 3.95
Multigame
1,700 (OBO)
Valparaiso, IN
Wanna join the discussion? Sign up for a Pinside account, or log in if you already have an account.
