(Topic ID: 280757)
Bally Transformer
By Kickout
  • 2 posts
  • 2 Pinsiders participating
  • Latest reply 3 years ago by emsrph
#1 3 years ago
Looking at Bally Rock Makers I picked up and have a question about the transformer wiring for 115V. I’ve attached a couple of photos. In the transformer photo the black wire comes in to the fuse block and then to #1 lead on transformer. The white wire connects to #5 lead. This looks correct per label. I need to connect the green ground.
Here is where I think something might be missing. On the transformer label on the inside of the box shows lead #2 and lead # 8 as 57.3 V. Leads #4 and #8 as 53.5 V. Should there be a wire coming off lead #2 connecting to the pin somewhere or to get a higher voltage should the wire on #4 be moved to #2? I am a little confused and want to make sure this is wired correctly.
Kickout
23A6910F-9141-4314-BF02-3AA144D6FE9A (resized).jpeg23A6910F-9141-4314-BF02-3AA144D6FE9A (resized).jpeg47984A4F-2878-4977-ACEA-0E5503B067D1 (resized).jpeg47984A4F-2878-4977-ACEA-0E5503B067D1 (resized).jpeg
#2 3 years ago
Quoted from Kickout:
Kickout
[quoted image][quoted image]
Yes, looks correct. To get 57.5 instead of 53.5 you need to move the red/white wire from where it is on terminal #4 to terminal #2. You can measure the AC at 2+8 and 4+8 with your meter before making the change.
Seattle, WA
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/bally-transformer-2 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
