I'm trying to fix a reset problem which eventually turns out into a booting issue on a CFTBL. I went through a lot of work but right now I feel stuck.
Note that the reset issue was so severe that the machine was rebooting during the startup sequence.
I'm trying to follow the pinwiki page about reset issue as much as I can. Here's what has been done so far.
Step 1:
- Changed all caps and bridge rectifier on the WPC board. ( I want the board to become reliable for a long time)
- Changed thermistor in the power switch casing
Reset still occurs
Step 2:
- Change the voltage regulator
Reset didn't occured anymore for a while. After a dozens perfect game withtout any reset issue, the reset reappears with the same frequency.
Step 3:
- I changed every diodes on the flippers (the left flippers diodes had very bad values)
- I changed the voltage regulator for a new one, since it seems that this was the part that fixed the game previously.
Now the machine do not boot anymore. The DMD is displaying random dots. Where should I look from there? I'm pretty sure after a double check that every connectors have been correctly replaced, but I may be wrong.
