Hi everybody, I could use some help figuring out a display problem on my Totem machine. Immediately when I power on the pin, the player 3 & 4 displays shows all ones (111111). I've taken a picture of this and attached it to this message. I've moved the score boards around - swapped 2 & 4, and 1 & 3, and the problem stayed in the same place. I've disconnected one score board at a time, and the problem persisted. So it seems the problem is either in the main board, or the connectors from the main board. I've cleaned all of the edge connectors and re-terminated all of the pins in all of the connectors on the main control board. So now I am thinking I have a problem on the main control board. Everything is fine when I run diagnostics. If I play a 4-player game the displays will begin to operate normally. But up until that point, I get all 1's.
This pin has a Rottendog power supply, and I've moved the battery backup off the main board. Also, after the game boots the credit display shows something funky - in the photo it looks like a 4 with the bottom segment of the 4 missing. That display is fine - there are not four credits in the machine, it's garbage data.
Has anyone seen this problem before? Does anyone know the cause? I want to fix this problem. Thanks much.
