Quoted from Cheddar:1. The lock relay buzzes and blows the 10A fuse.
I have a breaker in it but here's the weird part. If I turn the machine on the lock cool pulls in no problem. When I start a game it get's through the score reels resets, ball count reset, and bonus reset and then the lock pulls in buzzes loudly and the breaker trips.
How do you know it's the Lock relay that's blowing the fuse? The Lock relay works fine when you power on. Will it eventually blow the fuse on its own without starting a game?
When you start a game other coils start drawing power. It may be that something is drawing more than it should, which starves the other coils and makes the Lock relay pull in weaker than before. That might be why it starts buzzing.
Quoted from Cheddar:2. Bypassed lock relay (always closed)
In this scenario the cycle finishes and the game over trip energizes and ends the game.
How did you bypass the lock relay? Did you wedge it mechanically somehow?
There's not a lot going on with the Game Over Trip relay:
If you're in 3 ball mode, try 5 ball mode to see if it works better. Otherwise, block the two switches in red boxes with folded paper to see if that helps. If so, remove one piece of paper at a time to figure out which switch is the problem.
/Mark
