I have replaced all 3 tranistors R51 and 56, the pot, dioide, and zener diode still no luck. There are no broken traces, all resistors are good, diode and zener diode are good. I have not replaced the larger capacitors, would this amke a difference.
This is the second board that I repair. The first I replaced the same as above plus the 2 large capacitors, this one is working. Can't get the second working.
Any ideas or should i replace the 2 large capacitors? Aside from the high voltage this board works great.
