UPDATE:
I've updated the information on github. It is pretty self-explanatory, but feel free to contact me if you have any questions.
https://github.com/KenH2000/Bally-Pinball-Clock
A few years ago I built a pinball clock (discussed above) using an Atmega328.
Basic parts needed:
* Atmega328 IC (aka Arduino)
* RTC module (clock keeps time when not powered on)
* Nixie Tube power supply (optional, supports original plasma displays)
* Small stripboard
* 20 pin .156 female J1 connector and female pins
* 7805 Voltage regulator
* 2 momentary push buttons
* 2 LEDs
* 2 220 Ohm resistors
* 1 10k Ohm resistor
* 2 10 uF capacitors
* 2 22 pF capacitors
* 16 MHz clock crystal
* DC power jack
* 12V/1A plug-in power supply
* misc electronics -- wire/headers/solder
You plug the board into a Bally 6-digit display, and it shows the time.
I'll post the build details on my github page (give me a few days to get the documentation written).
If someone wants an affordable, fun DIY project, you can build the whole thing for about $25.
https://github.com/KenH2000?tab=repositories
