Helping out a friend with a Stern Flight 2000 pinball, and we've got a problem that has got us at a total loss. The game was playing fine until one evening a coil decided to lock on and smoke while the game was in attract mode (Right top kicker). The game was shut down as soon as we realized the coil was locked on. The next time the machine was turned on, the transistor for that coil (Q17) failed violently and spectacularly as soon as the switch was turned on.
We pulled the driver board and I replaced Q17, C12, CR17, and R42 with brand new parts. (See highlighted section of attached schematic.)
We then replaced the melted coil and verified that the diode was wired correctly.
When the game was turned on, the coil seemed to partially energized, and R42, the 330ohm attached to the base of Q17, burned up in short order. (Red arrow in attached schematic)
Since then, we have replaced the coil again with a known good coil, pulled the driver board, replaced R42, tried again with the same result.
I then completely rebuilt the entire Q17 circuit again, replacing Q17, C12, CR17, and R42 a second time, again with brand new parts.
Same issue. As soon as the game is powered up, the top right kicker partially energizes and R42 burns out after about 10-20 seconds. As long as J5 (playfield connector
R42 is a 330 ohm, 1/4 watt resistor. If R42 was connected directly between +5V and Ground without CR17 or R41, it would still only be drawing 0.076W. That's well withing the 1/4 Watt rating.
At this point I see only two possible sources of the problem:
1. Capacitor C12 is shorted / leaky and applying +43V to R42 or
2. There is AC voltage present at J5 Pin 7 that is crossing C12 and flowing through R42 and burning it out.
The issue with both of those is that I have replaced C12 twice with brand new caps of correct value and voltage rating, and I have verified with an oscilloscope that there is no AC voltage present on J5 Pin 7. (Which, if there were AC there, it should be on the whole solenoid bus and would be burning out all of the 330 ohm resistors on all the driver transistors.)
So unless I got a bad batch of caps, I have no idea what is going on. Any ideas?
