(Topic ID: 238850)
Bally Star Trek Roll-Under Targets only score occasionally
By Pinslot
5 years ago
  • 9 posts
  • 5 Pinsiders participating
  • Latest reply 5 years ago by Pinslot
#1 5 years ago
Hi,
Sorry to come again with a switch problem. This is driving me nuts. I have cleaned and adjusted these switches several times and replaced the capacitors just in case.
They work for about 5 games and then become unreliable. Is it possible that the switch "leaves" have become so worn that as the ball rolls over them they don't spring back?
Should I be thinking of replacing the whole switch mechanism under the playfield or should I be looking at something else?
Thanks in advance for any hints.
Regards,
Stefan
#2 5 years ago
If you're talking about the rollover lanes, they shouldn't have capacitors.
How did you clean the switches? These old switch contacts are usually black with oxidation and will not respond to the dollar bill trick or cleaning with alcohol. I use a Dremel with an abrasive buff (like a 3M scotchbrite pad) and give the contact a very short burst at the lowest speed. This should be enough to clean off the oxidation without damaging the gold plating.
You have nothing to lose by trying this. Worst case scenario is you take off some of the plating and the switches become unreliable and need to be replaced, which is exactly what you are facing now.
#3 5 years ago
Are you cleaning with a business card or similar? The gold contacts can be ruined if cleaned with a flexstone as one does with EMs.
#4 5 years ago
Yes, I'm cleaning with a business card. Sorry, I referred to them as roll-under targets. I mean the two rollover stars in the top left-hand side of the playfield.
#5 5 years ago
Quoted from Pinslot:
Thanks for clarifying. Yes the star rollovers will probably have capacitors since the ball travels over them at high speed.
Take a look at the contacts on the switch leaves. If they are black, the business card method is not working, you will need to try something more aggressive. As Jeff said, don't use a file since it will remove the plating, but if you're careful with something like Scotchbrite you can remove the oxidation without damaging the plating.
#6 5 years ago
Okay, I‘ll give that a go. Thx
#7 5 years ago
If this doesn’t help and the switches are so worn from use that the gold flashing has worn out (or they had been cleaned with something too rough) you might try tweaking one or both blades just a tiny bit so the points contact each other at a “fresh” spot.
#8 5 years ago
Just replace the switches or the contacts on the switches. No telling what these switches have gone through in the past 40 years. I just replace all the switches or the contacts as a matter of course these days as it saves a lot of trouble down the road.
#9 5 years ago
I buffed then with a Dremel and they are working quite well for the time-being.
Thanks for your replies.
$ 10.95
$ 100.00
$ 179.00
Pinball Pimp
2,000 (OBO)
New Brighton, PA
Retro Electro Designs
$ 22.50
$ 95.00
Pinball Mod Co.
$ 18.95
$ 115.00
10,000 (Firm)
Santa Ana, CA
$ 110.00
Gilbert, AZ
This page was printed from https://pinside.com/pinball/forum/topic/bally-star-trek-roll-under-targets-only-score-occasionally and we tried optimising it for printing. Some page elements may have been deliberately hidden.
