On start up I get 7 led flashes on the mpu board but no start up , fuses is ok, checked the test points on the rectifier board ,tp1,2,3 &5 were ok but tp4 was bad reading around 0.09 to 0.00
Are you measuring AC voltage ? If Yes......
You are missing your 7.3VAC ....... general illumination!
1. check fuse F5.
2. If the fuse is OK, remove the fuse and check the input AC voltage at E7 & E8.
@ If the above is ok, then you probably have a ground short at TP4 output.
my fault was measuring tp4 on dc , measured it on ac got a reading of 6.6 ,so why is it not booting after the 7th flash
when i turn the power on i get 7 flashes but no play mode ,all the score lights and credit lights do not light up
Did this Pin ever work for you ?
Did you just buy it from someone ?
If all the voltages on the boards are Ok; I suspect you have a Connector problem .
Remove and reseat the connectors on the MPU board ( Power off) !
If it still doesn't 'boot-up', wiggle each connector( MPU) one at a time( Power ON), and see if you have a loose/bad connection!
yea it worked good before it has just started , after turning it on and off around 2-3 times it will boot up , i will check the connectors out
Took the mpu board out found some cracked solder joints on the board at j4 ,re solder the joints ,
have turned the power on and off and is booting up every time
This page was printed from https://pinside.com/pinball/forum/topic/bally-star-trek-no-boot-up and we tried optimising it for printing. Some page elements may have been deliberately hidden.
