#StrikesandSpares
The good: Boots up (7 flashes on MPU), takes credits, starts game, scores fine, lights work in both attract mode and during game play.
The not so good: The only solenoids that work are the flippers, no kickers, no out hole, no chimes, etc.
I replaced the 11,000uf cap and a missing TIP102 transistor on the driver board and used a test lead to check each transistor to ground. All 4 chimes fire as does the coin lock and the relay on the driver board, but nothing else. Is it possible that 13 of the 19 TIP102 transistors are bad?
Also I have an Alltek Ultimate Solenoid Driver Board that I popped in and it won’t even boot with it in, I just get a solid LED on the MPU
Any suggestions would be appreciated!
