Hello all -
My Eight Ball has an issue that I need some assistance with. My credit, player 3 and 4 displays are all afflicted with the typical 00-33--55--77 pattern in test mode. In attract they just show junk.
I have replaced all connectors. I am testing with xpin led displays. I know that a bad decoder on one display can cause this behavior downstream...but...I get this problem with no other displays plugged in and using just the xpin.
Players 1 and 2 work perfectly with plasma and the xpins.
So, I suspect the problem is in one of the components on the MPU itself. The MPU connectors are also new. I am having trouble narrowing down if the 33-55-77-99 pattern would be caused by a bad digit enable, digit latch strobe, blanking, or segment data. I am suspecting U20 is the culprit...but wanted a second opinion. Confused as to which of these it may be as it looks like there is no wire that is common to displays 3AI, 4AI and 5AI but not 1 and 2.
Thanks to all -
-scott
